Question about HP Photosmart D7460 Printer
Where to disable color management in printer driver dialog box
I have an brand new Imac, brand new CS3, brand new HP Photosmart D7460. I just did some work on Illustrator and the colors are very weak in the final print. The instructions in color management in the print dialog box say "disable color management in the printer driver dialog box", and I can't find where to do that. I also do not see where to make a paper type selection.
When you go to print.  In the box that say's print with printer/presets there's another that say's copies and pages, scroll down to Color Management. Then you will see a Off (No Color Adjustment). Try that and also in the same dialog box is Print Settings that's where you put your paper type selection. Hope this helps
Posted on Mar 15, 2009
How to install hp photosmart 2573 all-in-one in my computer
connect all power and data leads to your computer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
http://download.cnet.com/hp-photosmart-2600/3000-2116_4-69704.html
http://download.cnet.com/hp-photosmart-2570/3000-18489_4-81851.html
Aug 06, 2012 | Generic 2 Pc To 1 Usb 2.0 Device Ab Switch...
My hp photosmart c4480 is printing in horrible color, redish tint and hazy. i just installed brand new color and black ink and can't get my pictures to print right. Help!!!!
Hello Friend,
First of all please check for correct drivers for printer.
Secondally : Please draw three different - different color boxes in word and print them on you printer and find out which one color is missing. Example as follows.
Apr 06, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
I have a d7460 hp printer and the magenta ink cartridge is empty, but I need to print something very important by tomorrow morning and it won't print. It says that it's "unhealthy" to print in...
From your printer properties, go to the "Printing preferences" button on the "General" tab. On the "Color" tab, select "Print in grayscale". That should take care of it for ya.
Apr 21, 2009 | HP Photosmart D7460 Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Dark prints when printing from my Imac using Leopard
I was also having problems with my Epson scanner on my iMac. I read that the best way to solve Epson's problems is to (1) uninstall all Epson software from your HD, and (2) download the appropriate drivers from Epson and install them.
Note: The Epson R1800 has two drivers: the most recent is an update. So, you must first download and install the Printer Driver v6.12. When that's done, then download and install Printer Driver Update v1.02.
I did that and I still got dark prints. Then I got an inspiration. In the Print dialogue box, I changed my Printer Profile to the paper I was using, Epson Premium Luster Photo Paper, instead of using sRGB and/or Adobe RGB. Specifically, I used SPR1800 PrmLstr PhotoRPM.icc. The next test print was virtually spot on to what was displayed on the screen. I am now a VERY happy camper.
Please pass this info onto anyone else who can use it.
Tim Calderwood
Sep 11, 2008 | Epson Stylus Photo R1800 InkJet Printer
Can you set default to print using only black ink?
Wow, what an incredibly unhelpful answer. Thanks, HP shill.
The answer is no. Selling ink is how printer companies make money, and they will do everything possible to make you buy more ink, even when you don't need it.
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7460 won't print
Did they suggest uninstalling it from device manager, completely and downloading the new vista driver fo your printer off the HP website??? and then installing this.
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart D7460 Printer Logo
3,308 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
