Question about Belkin Wireless Keyboard/Optical Mouse f8e832-bndl
Belkin wireless keyboard receiver won't work with my laptop
I have a belkin wireless keyboard . the receiver has two connectors that won't work with my laptop and no usb connecton. can I use this keyboard with my laptop that is wireless enabled?
  • Jason Edinger May 11, 2010
    What kind of connection does the receiver have, ie, how does it plug into the computer? USB? P/S2?
    President:
  • 623 Answers
Yes and no...
"Wireless enabled" means you do not need a separate adapter to connect to a wireless NETWORK or computer, not a peripheral device.
I assume the two connectors are PS/2- plugs - one pink, the other one green. What you need is a PS/2- -to-USB adapter that should have come with your keyboard. PS/2-in, USB-out, either with or without the cables (see picture)
belkin wireless keyboard receiver won't work with  - moz-screenshot.jpg7d83cbd.jpg
Posted on Dec 18, 2008
Belkin wireless mouse driver f8e832 mse
You should not require a driver for this wireless keyboard/mouse combination, but you will need to plug in the USB receiver unit. http://cache-www.belkin.com/support/dl/f8e832-bndl_manual.pdf
Apr 21, 2014 | Apple Computers & Internet
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
I just changed battery in my BELKIN wireless keyboard, how do i reset my keyboard
look for a button on the bottom that says connect...or possible pull the USB from the receiver and reinstall
Feb 10, 2011 | Belkin Wireless Keyboard and Mouse...
How to connect my key bord to pc
Any "modern" keyboard either has:
* a "round" connector (first used by the IBM 'PS/2' line of computers, 30-some years ago)
* a "flat" USB connector
* no connector at all, because it is a "wireless" keyboard, communicating wirelessly to a "receiver" that has either the 'PS/2' connector or the USB connector.
So, "how to connect" depends on which connector your keyboard has, and what sockets your motherboard has.
Sep 30, 2010 | Computers & Internet
I purchased a new Belkin wireless mouse and it worked a few times but not is unresponsive. Help.
press both the reset button of the wireless mouse and the receiver. also check the batteries
Mar 28, 2010 | Belkin Wireless Keyboard/Optical Mouse...
WHERE IS THE RESET BUTTON ON MY WIRELESS BELKIN KEYBOARD ANTONE??
had the same problem and tried pressing down the connection button on the keyboard at the same time as the connect button on the receiver. If you press down on both intermittently then they should pick up each other.
It seems there isnt a reset button like there is on the mouse, which is what i was looking for on the keyboard - i presume they mean the connection button / LED light but you have to press the receiver button at the same time.
good luck!
Mar 02, 2009 | Belkin Wireless Keyboard/Optical Mouse...
PS/2 to USB adapter
does windows recognise the new hardware and install drivers for it when you plug the wireless sender in to the laptop ?
try opening up device manager and see if the deive in question has an exclamation point over it , if ti does remove and reinstall
hope this helps
Dec 31, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Wireless Keyboard from Belkin
No you shouldn't .Belkin is recognized but most any computer as being compatible.If you've plugged into a live USB port the computer will see it.***Make sure you've installed batteries if it holds them and check the pin reset underneath the board and use it.There is also a rest on the keyboard receiver .
Aug 10, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
May 16, 2008 | Belkin (F8E832-BNDL) (DBF8E832BNDL)...
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Belkin Wireless Keyboard/Optical Mouse f8e832-bndl Logo
375 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
