Question about Canon i860 InkJet Photo Printer
The power light went off and will not turn on what is wrong?
I received a message that the printer was off line and to turn it off and on again. I did and it will not turn on (will not respond to on off button).
Is there a blown fuse? There is power to the outlet.
  • Anonymous Jan 22, 2009
    Same problem!
  • melsem Apr 05, 2009
    I have the same problem. I printed several documents yesterday and the light went out. Will not respond when I try to turn it on. Where can you buy parts to fix?
  • 49 Answers
The Canon Service Manual says that you have a bad AC adapter or a bad logic board on page 1-6. You can download a copy at:
http://printer1.blogspot.com/2009/01/canon-i860-i865-service-manual.html
Note the password on the page to open the compressed PDF file.
Posted on Feb 24, 2009
2001 Chevy venture will not start. We had an inspection done yesterday, oil change & a power steering line replaced As well. Looks like they had moved the wiring harness & also taped it when this...
-Battery is full...? If so check for corosion battery cable.
And make sure good connector (Tight)
-If all are good and just Click but can't turn. >>> Need new starter.
Mai
Apr 02, 2013 | Cars & Trucks
All lights are flashing and it says Error 0xd0620130 reset power. I have unplugged all lines and even uninstalled it then reinstalled the software. After that it was fine till I tried to print...
Hope this helps, you need to Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Apr 27, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jun 24, 2010 | Brother HL 5250DN Laser Printer
My HP Laserjet 2420dn will not print and is displaying message '49.FF95 service error'. How can I fix this..?
This could be a firmware fault on the main formatter board inside the printer
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware update
Apr 26, 2009 | HP LaserJet 2420dn Printer
Turned off my printer and now it wont turn on
If you can't see the lights on the panel it might be the power adapter or the connection at thre printer itself
Feb 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
Problem w/3300 laser printer
Take the unit out right away and reseat it again,repeat if nessecary.
Oct 01, 2008 | Minolta magicolor 3300 Laser Printer
Hello, RE: LEXMARK Z1380 The light on the power button keeps flashing and im receiving a message telling me the printer cannot communicate with the PC. I have reconnected all the wires, i have also...
This is going to sound crazy, but I just spend days with the same cannot communicate with the printer problem with my Z1300. I was ready to buy a different printer when I decided to look on Lexmark's site. The fast blinking power light indicates a paper jam. I thought... sure.. uh huh. I turned off the printer, took the stack of paper out, which didn't seem jammed at all, put one piece in, turned on the power ... and the blinking had stopped. Yep ... after doing the countless fixes I found on the net... including reinstalling drivers.. deleting usb ports.. etc... it was a paper jam! The printer works fine again. Hey.. what would you expect from a printer that cost under $25. lol
Jul 15, 2008 | Office Equipment & Supplies
My DVR-625, wont even turn on.
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
Nov 22, 2007 | DISH Network DVR-625 DTV Receiver /...
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Canon i860 InkJet Photo Printer Logo
288 people viewed this question
old marine
old marine
