Question about Compaq Armada M700 Notebook
I have a 2nd hand companq armada M300 notebook with docking station. It came with power lead which appears to fit both docking station and laptop - the machine powers up fine if I plug the power lead direct into the laptop but I cannot figure out how to charge the battery. I was advised that the battery is brand new - can you advise as to how to charge it, ie where do I connect the power lead and how long should it take to fully charge the battery?
  • lilacblushes Dec 21, 2008
    sorry for the delay in rating the solution, I have been ill and not able to get online.
    I have tried to charge the laptop but fear that the battery is dead although the seller advertised that this had been replaced with a new one.
Plugging in the power lead into either socket (laptop or docking station) should automatically start charging the installed battery (if it is working).
Li-ion batteries have a limited shelf life and even if "new" may not work if they have been left standing a long time. These "smart" batteries have some circuitry inside that drives the power indicator guage and could prevent the batteries from working if the Li-ion cells are degraded.
Posted on Jan 01, 2009
    President:
  • 1,073 Answers
Http://h18000.www1.hp.com/products/quickspecs/10381_div/10381_div.HTML
There is a manual for your armada, the battery is inside the hinge, and you put the charger in the hinge..not sure if it on left or right side of it
If the battery is healthy then it will be full charged in a couple of hours from emty to full, if the battery ise´nt that healthy, it can take 10-12 hours of more
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 18, 2008
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
My compaq armada m300 wont recognise new hardrive
just try with fixing the hard drive connection properly and in bios also check how much capacity motherboard can support .according to your specification it will not support the higher capacity hard disk .make sure you installing the new hardidsk as same capacity of your older hard drive.
Nov 25, 2009 | Compaq Armada M300 Notebook
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
Dock station for hp pavilion
You need to check the plug that plugs into the laptop to determine that you don't have a faulty lead or plug. Test it with a multimeter and wriggle the plug to see if the voltage reading remains steady. If it doesn't then it could be the lead and this is easily repaired.
You may be able to borrow an adapter to test your laptop's connector.
If you determine the fault is with the laptop then problem is most likely the connector socket on the laptop, it most likely need re-soldering onto the motherboard, or needs to be replaced. This requires the laptop to be dismantled completely.
A docking station would solve your problem because the docking station has its own power connector and you plug the existing power adapter into the docking station.
My HP is connected to a docking station, the other advantage is that the docking station has several more ports than the laptop which is useful.
Feb 12, 2009 | HP Pavilion dv6000z Notebook
Compaq
I don't think that version has WIFI. You can find the manual for it here.
http://dl.owneriq.net/b/b93bfeaa-7290-44a5-8a4f-d2b10a651de1.pdf
Please don't forget to rate me.
Feb 01, 2009 | Compaq Armada M300 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
No internet when docked.. needs network controller
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
Sep 16, 2008 | Dell Latitude D600 Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
Halp of the laptop
with the indulgence of IB4G2008, you can try Fn + F3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Compaq Armada M300 Notebook
Removing laptop from docking station
If you have the ArmadaStation EM:
The issue of removing the notebook is compounded by the fact that the ArmadaStation EM uses a motorized dock/undock mechanism to remove the notebook. When the expansion base has no power, it is unable to eject the notebook with the motor
 To manually remove the notebook, use manual eject lever to push notebook out of ArmadaStation EM. The manual eject level is a small white lever located inside the back cover of the base. To remove the notebook, push the white lever to the left. Slight pulling is required to remove the notebook completely out of the base.
Hope this helps!
Jan 15, 2008 | Computers & Internet
Compaq Armada M700 Notebook Logo
186 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
