Question about Mercury Electronics KT266A Motherboard
NO DISPLAY I HAVE MERCURY PI845GVM-AGP MOTHERBOARD.I SHORT THE POWERON CONECTION PIN.POWER CANNOT REACH THE MOTHERBOARD .I MANUALY START THE SMPS CONNECTION .POWER COMES BUT NO DISPLAY.PLEASE SEND SOLUTION . ADVANCE THANKS
  • 1 more comment
  • adaikala raj Mar 30, 2007
    i using onboard vga .i things the problem is in motherboard .i wnat to know about chiplevel servicing in motherboard.Please give link to develop my knowledge .Already i know monitor servicing.
    Advance Thanks
  • Anonymous Jul 28, 2008
    I HAVE MERCURY PI845GVM-AGP MOTHERBOARD.I SHORT THE POWERON CONECTION PIN.POWER CANNOT REACH THE MOTHERBOARD .I MANUALY START THE SMPS CONNECTION .THERE IS NO CONTINUE POWER WHEN I LEAVE SHORTING.POWER COMES BUT NO DISPLAY.PLEASE SEND SOLUTION .
  • aroop Oct 19, 2008
    i have mercury pi845gvm-p mother board, i need total jumper setting & Pannel setting like Power, Hdd, Resw, Led etc.
First Remove the Cmos Battery. Then remove external components from motherboard (like Ext .VGA, SOUND, Processor) Using Iso propile Alchol clean the motherboard. then after 1 hour you can give the connection. i will work. i used this method to solve more than 140 motherboard.
Posted on Oct 30, 2007
    Problem Solver:
  • 4 Answers
It may be the prob of SMPS's out. The correct o/p signals may not be getting from it.so that the display section won't work.
Posted on May 07, 2010
Plz tell me the link where i can get the books to read chiplevel about mother boards....
Posted on Dec 03, 2008
  • 97 Answers
Do not atempt to replace any componeent but capacitors. You need a falt pack IC solder station to do the job. A new motherboard is in order.
Posted on Mar 31, 2007
  • 24 Answers
Are you using an AGP video card or pci? try a differnt video card and see if that works. you might also try pulling out everything except processer and video and see if you are getting any system beeps, you may have to hook up a case speaker stright to the board for sound, if no beeps then you prob have a bad board.
Posted on Mar 29, 2007
SOURCE:
Plz sir help,tell how can attach the SPKR1,+HD-LED,RESET,PW-BT,ACPI-LED wires on Mercury PI845GVM-AGP motherboard
here you go http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=507
Mar 28, 2014 | Mercury Computers & Internet
Where connect LED,RESET etc wires are attached
Please refer to the following list of the PANEL1 pin assignments.
Pin Signal Pin Signal
1 HD_LED_P(+) 2 FP PWR/SLP(+)
3 HD_LED_N(-) 4 FP PWR/SLP(-)
5 RESET_SW_N(-) 6 POWER_SW_P(+)
7 RESET_SW_P(+) 8 POWER_SW_N(-)
9 RSVD_DNU 10 KEY
1 SPKR 2 NC
3 GND 4 +5V
AUDIO2
USB3
SPKR1
These are all contained in the users manual. If you don't have one go to Mercury website and download it.
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
My board Mercury PI845GVM - AGP is not working help me please
101 % Working first you have to download
1. Universal audio architecture which will enable your motherboard to detect audio driver it
can be downloaded from here.
2. Then download its driver from Link 1 vga
Link 2 audio.
Its working
Jan 24, 2011 | Mercury P4VM800M7 Motherboard
My computer want come on with the power the light is on on the back of the tower but it will not come on when i push the power button
you need to check the SMPS first remove the 24 pin conectior to the motherboard from the smps and short the green and black pin if the SMPS fan is working there is no problem in the SMPS conect tthe 24 pin conector to the motherboard then remove the 4pin conector from the motherboard from the smps and switch on the computer of the computer fan is working you have froblem with *********** board
Jan 17, 2011 | HP 1GHz Compaq/ Desktop Computer (RB1GPKG)
Where do i get mother board driver for mercury motherboard
Hi!
Here u go!
http://www.mercury-pc.com/product-drivers.php?productid=507
All avalible drivers for your Mobo!
Good luck to you!
Please take a minute and rate me
Nic
Feb 04, 2009 | Compaq Computers & Internet
I need a mother board drivers cd for mercury PI845GVM-AGP, V:5.0A
There are a lot of equivalent model available on other manufacturer websites. but the best way is to run belarc advisor and check the drivers needed. From there you can then download drivers and burn it in a cd.
Hope this helps.
Dec 01, 2008 | Mercury Electronics KT266A Motherboard
Hello....
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aapor-13
Oct 05, 2008 | Mercury P4VM800M7 Motherboard
Mercury Electronics KT266A Motherboard Logo
193 people viewed this question
Top Mercury Electronics Computers & Internet Experts
Alun Cox
k24674
Are you a Mercury Electronics Computer and Internet Expert? Answer questions, earn points and help others
