Question about LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator
I have an LG GR-409GUPA Frige Freezer which has recently started being very noisy, not all the time, but periodically when the motor kicks in. Sometimes it stops if you open the freezer door, and sometimes if you move it slightly it calms it down, other times nothing works! It's about 4 years old and i've never had a problem with it before...
    Top Expert:
  • LG Master
  • 12,962 Answers
Weak motor spring lets motor hit shell on startup due to torque. experiment with Shimming the motor mounts to reduce/eliminate noise.
Has no effect on motor performance/longevity.
Posted on Sep 08, 2017
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 62 Answers
SOURCE: Noisy LG Fridge Freezer
most likely the evaporator fan is hitting some ice that has formed on the mounting shroud. You will have to defrost the unit by leaving it off over night. Also what contributes to this broblem is the location of the temp sensors. they should be checked that they are in the holders for them and not buried into the foam insulation. There is on in the ref on the top of the liner and one in the freezer. These pop off. remove them from the foam and insert them into the holders. If you can't do this then it may be wise to use a service person to do check it.
Posted on Dec 18, 2008
tomsat69
  • 219 Answers
SOURCE: fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
Posted on May 10, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
Why does my frige motor turn on when I close the door and off when I open door?
It's designed that way for energy saving purposes. The motor shuts down when the door is open so that it's not producing more cold air to just fly out the door. Then when the door shuts, the cooling mechanism kicks back on again for business as usual.
Oct 20, 2014 | LG Refrigerators
Noisy pump when we run the dishwasher
Recently had a similar experience. Sounded like grinding noise for a period of time. Then motor stopped. Motor bearings were shot. Had motor replaced under P.S.E.&G. Service contract. This utility company offers appliance contracts for the home. P.S. serviceman indicated they will only do that once for the contract. This is an expensive part. If you don't have access to a contract be ready for 130.00 or more for a new Motor and more to have it installed if you are not handy. Service man removed front kick plate and dropped motor without removing dishwasher.
Apr 19, 2014 | Kenmore Dishwashers
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
Freezer and frige blowing warm air. The unit is a 6 year old side by side. Is it worth calling a repair man or just replacing? Thank You Oh the motor still runs and I hear a sound as if the compressor...
To start a new check it will be good to shut off the fridge for about 8 hours, Now during this period clean the set and check the thermostat , the compressor relay mounted on it.
When the power is switched the compressor must click and start up, if not check relay and capacitor of the motor.
When the compressor runs for about 2 hours there must be coooling, if not the compressor is faulty or the gas pressure is down.
It must be estimated and decided.
Sep 26, 2010 | Kenmore Refrigerators
Dec 18, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Motor on frige won't kick in
hi .thanks for the question . you said the motor is on .you mean the fan in freezer is on . but the compressor is not running . i would replace the relay on the compressor .thanks the appliance doc
Oct 05, 2008 | Refrigerators
My frige has two handles, and the bottom handle for the frige was loose and came of, how can i get a new handle for my frige. Its a LG Model GR-642QVP Serial No REFER BAR CODE LABEL A.3850JZ0373A
Sounds like you have a UK model LG refrigerator. Go to www.lge.com and from there you can select your region and get the phone numbers to call the UK LG Parts Dept. to purchase a new handle. Hope this helps.
P.S. I work for LG!
May 27, 2008 | LG Refrigerators
LG LFD22860 Stainless Steel Bottom Freezer French Door Refrigerator Logo
69 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
