Question about Sony CDP-C445 5-Disc CD Changer
CANNOT OPEN PLAYER
I WAS PUTTING IN A NEW DISC AND THE PLAYER CLOSED BUT
JUST SEEMED TO BE SPINNING AROUND AND NOT PLAYING. NOW IT WON'T OPEN AND JUST KEEPS MAKING A NOISE.
    New Friend:
  • 35 Answers
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Posted on Mar 02, 2009
  • sandyf863 Dec 24, 2010
    THANK YOU SO MUCH! It worked like a champ! I seem to always have problems with a CD player during Christmas. You were a life saver! Thanks!
    -Sandy, Maine
I have just the dvd player, the player keeps ejecting the disc and not playing it
Could be lots of things, but here are a few easy ideas:
1) Is the disc Blu-Ray? A regular DVD player can't read Blu-Rays.
2) I think all DVD players can read CDs, but if the disc you're putting in is a CD, maybe that's the problem.
3) Maybe the disc is dirty. Wet the disc, wash it with dish soap (or hand soap, then rinse it clean and dry it off. You can use a cloth or a paper towel for washing/drying. When washing and drying, make motions across the disc from the inside hole to the edge; don't swirl around the disc.
4) Maybe the disc is not the same region as the player. https://en.wikipedia.org/wiki/DVD_region_code
5) You've got a PAL (European) disc and an NTSC (American/Japanese) player.
Aug 02, 2015 | LG Televison & Video
Portable DVD player won't work
Try clean lens or change the CD hope it will work.
Sep 13, 2012 | LG Televison & Video
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My PS2 slim wont spin a disc it takes you to the game settings but nothing else
Well has it been dropped? If so more then likely the guide rail fall out of place and can easily be poped back in place. A good way to see if its your laser or guide rail is to fined the hole that when the lids closed this pin goes in the hole so the ps2 knows the lids closed and stick a piece of paper in that hole with lid opened. Now it should act like the lids closed. See if the laser produces a red beam or strange noises. Maybe even the little black piece at the back that stops the disc from spinning isnt working right. But dont get worried as theres a pin on the lid that makes the black piece pull back from the disc when lids closed so it might be stopping disc from spinng while its open. Several diffrent solutions need to know how you know its not spinning. If your just putting your head to it and cant hear it spinning then you will need to trouble shoot.
Nov 21, 2010 | Sony PlayStation 2 Slimline Console
When playing a DVD, we experience frequent stops and starts..
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
Jun 05, 2010 | Zenith DVD2381 DVD Player
After loading a disc it says "no disc"
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Aug 25, 2009 | Durabrand DUR7 Portable DVD Player
Disc Tray won't stay closed on Playstation 2
I HAD THE SAME PROBLEM OUT OF MY PS2 AND MY SON PS2. I FOUND THIS NEW SITE THAT TOLD ME WHAT WAS WRONG FOR FREE AND FIXED IT WITHIN A FEW DAYS. http://PS2EARTH.synthasite.com I LOVE FIXYA BUT THIS SITE IS BETTER FOR GAMERS. THEY CARE.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
745 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
