Question about Panasonic Workio DP-150PA Copier
Hi again its bbjj again.am glad you replied me 'dr bob'.on the same DP1820.i have done service and the spanner hasnt gone.maybe am overlooking anything.on switshing on it starts by showing please wait then its like warming up then shows ADD PAPER tray1 and the spanner.otherwise it doesnt show an error code.have i overlooked something or maybe i have not cleaned a certain area.please assist urgently and very kind regards.bye my number is 254-720-978878
  • BENJAMIN NJOROGE Mar 30, 2007
    hi dr bob1,
    hi again and thanks for respopnding.this DP1820 is really giving me a hell of time.i have reset the PM cycle c70 to o and even i tried the optic cycle c86 but no success yet the spanner is still there.please kindly dont tire and give me more hints.kind regards and hope to hear from you soon.bye
    Problem Solver:
  • 10 Answers
Hi BBNJ try this 1. To select the Service Mode The service mode is selected when ?FUNCTION?, ?ORIGINAL SIZE? and ?3? keys are sequentially pressed, then F1 will appear in the display. 2.press number 5 to get f5 on the screen then press green start button 3.you should see `c00` on the screen key in 70 the screen should read c70 press green start again key in 0 and then green start button this should switch off the spanner 4 2. To exit the Service Mode The service mode is reset when the ?FUNCTION? and ?CLEAR? keys are pressed simultaneously kind regards Dr Bob1
Posted on Mar 29, 2007
How do you reset the Inspect indicator with the service spanner on the dashboard of a 2007 Polo Classic 1.9 TDi
Hi,if the spanner comes up and there is a beeping sound,try turning the ignition off then push the button in thats near the spanner clock,hold it for a cupple of seconds then still holding it down turn it from left to right and let go,turn the ignition back on and hopefully its gone,if not try again just in case you made a mistake.
hope this works for you,all the best.
Aug 08, 2016 | Cars & Trucks
What would make the speedometer work on my 1997 volvo 850 and the odometer not work ?
Hi Bob, I'm glad to help!
Bob, I'm summing you have the electronic instrument cluster so I'm basing my answer on that. The Volvo has a big problem with some of the pins on the circuit board losing contact and needs to be re-soldered. Note: This is not always the case but certainly worth a try. If you do not know how to do this then its best to find someone that's done it before. CAUTION: If you try this it could possibly stop other areas of the cluster from working BUT, I've only seen this happen maybe one out of 100 time so I just wanted to make you aware of the possibility that this could happen. NOTE: This only applies if you have the electronic digital instrument cluster. Hope this helps and have an awesome day Bob. Give me a call 314-374-5218 Al.
Jun 18, 2014 | 1997 Volvo 850
Cannot get fuel filler cap off fat bob
Hi Anonymous, do not be embarresed thats what warranties are for.
Take a ride over to your local dealers service department and they will be glad to help you. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 15, 2014 | Harley Davidson Motorcycles
Had a service and the spanner indicator was not removed. Garage has now gone so how do you get rid of the spanner from the display
Hi,,ok i know how to reset the spanner on a rs 125 and there is a good chance it is the same procedure for your scooter.
hold the mode button down for 5 seconds,,,still holding it turn the ignition on,,keep holding mode for 15 seconds with ignition on,,the spanner will clear,,,if not repeat again.
Mar 23, 2011 | 2005 Aprilia Sportcity 125
How do i reset the service spanner symbol on my aprilia 125 leonardo sport city scooter
Ok, disconnecting the battery does NOT reset the service light. To reset the service light (spanner symbol) on dashboard you must hold the mode button for about 5 seconds with ignition OFF then while still holding the mode button turn ignition on, continue holding the mode button for a futher 10 - 12 secs and then it should just disapear. This solution was brought to by RPMs. Mobile motorcycle service.
Oct 30, 2010 | 2007 Aprilia Sportcity 250
The machine shows spanners
If you press the ' clear ' and ' 8 ' button, at a time both has to be pressed continuously then after two to three seconds you can see some code like "c44", "c43", c26, "c01".
the spanner means it is call for service. you have to call a service engineer if the symbol is blinking even though you may clear some of these with the codes.
These spanner blinks then it is saying that some part has gone bad and it need the replacement , service, reset of the code. any one of the three.
Nov 18, 2008 | Toshiba 2060 Copier
Help me urgently on DP6030 panasonic photocopier
I have a problem with a DP6030. code says J87. checked but can't find any paper misfeed.
May 15, 2007 | Panasonic Workio DP-150PA Copier
Hi and sorry to bother you too much
hi im jules_09.Check you home possition sensor there are 2 sensor positoned at the optics and scanner checkm it then replace the 2
Mar 30, 2007 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-150PA Copier Logo
142 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
