Hi,my acer orbicam is not working.It only worked twice since I bought it and it es saying I should go online to fix it
Acer orbicam- aspire 3680
Whenever it displays this try and reboot your system and if the problem persist, then t to reinstall the driver for the orbicam. good luckk
Jun 12, 2008 | Acer Aspire 3680 Laptop
Acer orbicam
http://support.acer-euro.com/index.html
This is a link what you should go and read.
Other ways you can troubleshooting and if you can find a solution to enabled it good!
Aspire 5610-2762 Orbicam not working
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Orbicam not works (acer aspire 5610Z)
Go here:
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=97481&CFTOKEN=91974135
Click Notebook then find your model from the options.
Mar 18, 2008 | Acer Aspire 5610 Notebook
Acer orbi cam
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Mar 11, 2008 | Acer Aspire 5610 Notebook
Acer orbicam
First u remove the orbicam drivers and restart.After windows booting,u insert orbicam driver cd and instal it.After installation completed,once again u restart the laptop.
Feb 25, 2008 | Acer TravelMate 3260-4874 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Acer Orbicam
can you clearly explain me
Feb 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
