Question about Cornea MP 704 17" Flat Panel LCD Monitor
Polarity for power supply for cornea mp 704 lcd monitor
I have a cornea mp 704 lcd monitor given to me with no power supply it is a tft lcd monitor serial mp02280213 it state s only to use with power supply for manufacture model its lists a 12v 3 amp below FGCD # A0- NHA005A1 it has no digram for the polarity it has a barrle type connection was wondering if any body could help me with the center being positive oR negitive had a freind with the same one and he tried a power supply and it started smoking so dont want that to happen apprciate any support on where I can confirm the polarity for a proper and safe power supply to this monitor
    Top Expert:
  • Cornea Master
  • 46,092 Answers
There may be a virtually invisible polarity symbol on the case next to the connector.
Posted on Apr 21, 2017
sandrew
  • 2961 Answers
SOURCE: Cornea Monitor Troubleshooting CT1700
it could be something as simple as your power settings in control panel> power options, then the first window called power schemes pops up and all monitor, harddisk and system standby should be set at never. Also check on you monitor menu for any power saving options and turn them off. If the monitors still turn off then there has to be a deeper fault with the monitors and not with the power options.
Posted on Apr 28, 2007
sandrew
  • 2961 Answers
duplicate posting see below for solution http://www.fixya.com/support/t145139-cornea_monitor_troubleshooting_ct1700
  • 383 Answers
SOURCE: Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
Hdik
  • 51 Answers
SOURCE: Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Posted on Dec 22, 2008
MalKontent68
  • 748 Answers
SOURCE: Cornea 1810 monitor power cord
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
Posted on Nov 18, 2009
Testimonial: "thanks, my concern is the feed to the monitor,I had this monitor at home with no problem, also 2nd one no problem, had new tower, could it be that"
When I turn on my Cornea MP503 monitor on it has a message in a blue box saying Power Saving Mode and then goes blank and light flashes orange-green over and over.
Check the VGA/ DVI cable connection from your Monitor to PC, this also could be caused by VGA card on you PC that doesn't work properly, unfirmed connected to its slot etc, check also for unfirmed connected memory card/ RAM.
Dec 13, 2010 | Cornea MP 503 15 in. Flat Panel LCD...
What would cause my monitor to be in the " POWER SAVING MODE? "
check out if the electric alimentator are fine, the cords and the conections, check the properties too, maybe a stand by settings are on and make you this "power saving mode" if none of the anteriors was... then could be that the monitor have done the limit of hours, if the monitor was new try on warranty, if the monitor doesnt have warranty you can explain more about this trouble so i can help you more given you specific intructions
Aug 12, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
Where can i find a power cord for a Cornea CT1700? I live in Greensboro, North Carolina
josdcabr, do you need only the cord or the "black-brick" switch-mode-power-supply" 12vdc @ 3.5 amps rating. You might try unitedsale. com in Valley Stream N. Y. 12fixlouie
Aug 10, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Screen is black when turned on
You may have failure in the backlight inverter circuits (shorted transistors, failed inverter transformers), power supply (bad caps), bad lamp assemblies. If you are going to DIY repair, please look through my albums so you will know what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 21, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
Need driver for Cornea MP704
Hi
I have the same monitor on one of my test benches. For a long time I tried to find drivers for this because I thought it would make a difference. Finally a year or so ago I found a drivers company which said they had it. For $20 I could download it and many others. I did so and didn't really see much improvement when I installed it. I finally got to thinking that maybe I should look closer at this code I purchased. Well as I suspected this code was actually the Microsoft generic LCD monitor code which had been relabeled. I turned it over to Microsoft. But to answer your question I have never found drivers that are specific for any Cornea monitor. Sorry
Mar 24, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
External Monitor
No. This is almost certainly a setting issue. Go in to the control panels and change the way the monitor is used. I.E. extension desktop, mirror, etc. Then check the settings for the second monitor and make sure it is not set to some huge size or resolution. This is a function of the MacBook and OSX. I had a similar issue when connecting it to a 71" DLP.
Apr 01, 2008 | Cornea MP 704 17" Flat Panel LCD Monitor
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Power supply
Bs more specific with your problem.
Jun 23, 2007 | Cornea CT 1810 18.1" Flat Panel LCD...
Monitor not powering up
Try another monitor on that same pc, try your monitor on another pc. Next, check the data cable for any short.
May 08, 2007 | Cornea MP 704 17" Flat Panel LCD Monitor
Cornea MP 704 17" Flat Panel LCD Monitor Logo
78 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
