Question about Bang and Olufsen Beocenter 9300 Shelf System
18 year old Beocenter 9300 CD won't play most CDs
Cover closes over CD then a high frequency sound is emitted; sounds like CD is spinning but not being read. Other times sounds like the CD grinds to a halt and the CD cover keeps opening but CD merely spins or is already stopped.
  • 122 Answers
Cd unit unable to read disc,replace or try cleaning laser lens.cd clamper may be misaligned or faulty,check operation in service position(top up).
Posted on Jan 11, 2010
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
'Beocenter 9000' sounds problem
Hi talenso,
as the beocenter 9300 i assume its at least 7 years old. This model has 2 transformers in them one for when it is on standby and one during operation. I suspect one of these has degraded over time.
My best advice is see if you can go to your local store and buy one of those power boards that regulate the voltage coming into the unit. This may solve your problem, but my gut feeling is one of the transformers needs to be serviced.
good luck
smeags.
Jan 08, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9000 won't play cd,help
The most common cause of not playing cds is c2103 on the pcb under the cd mech.Try cleaning the laser lens also.
Jan 04, 2011 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9000 cd player problem. it won't start. the cover moves back to open and the player doesn't start..
the disc isnt being read. the laser lens may be dirty or the laser power cct may be faulty. check tr6108 and c2103 located on the servo board beneath the mech.(bc338/33uf16v).
Oct 25, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Problem playing CD's
beosound 9000? have you moved the unit.this unit requires cd mech suspension adjustment depending on how it is placed,eg. vert. flat horizontal.check handbook and adjust as required.if it has not been moved then workshop repair needed
May 17, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
856 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
