Question about Bose Lifestyle 12 System
Need to know the OHLMS rating for speakers
Bose Lifestyle Speakers - we are using back Bose speakers with a Panasonic system that sends at 3 ohlms. We need to know if that will damage either the Panasonic system or the speakers - are they compatible?
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
You can measure the resistance of the voice coil on the driver. Multiply that by 1.25 to get the approximate impedance. This is just an estimate, but will be fairly accurate on most woofers that have smaller magnets. If the driver has a large magnet, then you should multiply by 1.5 to 1.75 or so. Round result to the nearest whole number.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Feb 04, 2017
Hello! The impendance of the "speakers" does not be "minor" of the "system" . If your system is
3 Ohms, yours speakers must be 3 Omhs too, or 4, 6, 8... Use serial or paralel conectios. Ex.: 3 Ohms +3 Ohms in series = 6 Ohms ---- 3 Ohms +3 Ohms in paralel = 1,5 Ohms.
Sorry about my bad english, I'm just speak in portuguese.
Posted on Dec 19, 2008
How to equalize extra speakers?
The only thing you can do to equalize those speakers. Make sure that you have them in faze. + to + and - to - and left to left and right to right. Make sure that your speaker can handle the ohms. (the same ohms) for example If your amp is rated to handle 8 ohms then your speakers should have 8 ohms. The speaker wattage should also be abit more than what your amp can produce. Distortion is your worst killer of speakers.
Mar 26, 2012 | Bose Lifestyle SA-3 2-Channel Amplifier
I have a Bose lifestyle 38 and whenever I watch a show with a lot of background sound - ie music in a movie or crowds cheering for sports, it overwhelms the voices of the actors or the sports casters. How...
What makes background sound comes out from Bose lifestyle 38 system is because there is jack cable or a cable that has a jack mouth that brings out a mono sound is being inserted..
Mono cables, when inserted inside a wrong input,it's makes the sound comes out with a background noise just like the one you can hear from it now..it seems as if you are not using the right cable for connection..
To resolve these issue, you will need to use the right cable for connection, by doing these,you will get a clearer sound from you Bose lifestyle 38..
Also it can be from the settings inside the Bose lifestyle 38...So you will need to check both sides to resolve this issue..
You will need to use the manual to know the right cable and the right setting for clear volume..
You can download the user's guide from the below link..
http://www.retrevo.com/support/Bose-Lifestyle-38-Series-III-Home-Theater-Systems-manual/id/524dj979/t/2/
Hope it helped.
Thanks for using fixya..
Aug 15, 2011 | Bose Audio Players & Recorders
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
Do I need special speaker wires to hook up bose shelf speakers to my bose lifestyle deck? all I have is regular speaker wire at the moment
It comes with special connectors - not necessarily special wire.
You will need the Lifestyle Cables.
c35cb24.jpg Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2009 | Bose Lifestyle 12 System
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
I WANT TO SUBSTITUTE 191 SPEAKERS FOR DOUBLE-CUBES WITH MY LIFESTYLE V20 SYSTEM
Yes, there should be no issues at all with just using different speakers. Just connect the 191's as you would the cubes and you should be fine. Please rate my answer, thanks.
Apr 28, 2009 | Bose Virtually Invisible 191 Main / Stereo...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Integrated System (Bose Lifestyle) vs Component System
Better is a subjective term. Simpler vs complex is more accurate. I'd go for the separate components if conspicuity is NOT required and to allow unlimited future growth. Sub/sats have their place but nothing beats having full-range speakers alll around the room with some real horsepower to push them.
Dec 26, 2008 | Bose Lifestyle 30 System
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose Lifestyle 12 System Logo
240 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
