Question about RCA HD61LPW165 61" Projection HDTV
Color wheel was making a sqealing noise then locked up
Oiled color wheel and it loosened up-lamp lit up once after that but now lamp does not come on --think this is due to color wheel or do i have lamp problem too?
  • whorleyw9028 Jan 02, 2009
    possible noisy color wheel, picture get's grainy, sometimes the picture shuts down then comes back on. Any solution ?
  • 106 Answers
The clorwheel is the problem. Once the bearings go bad in the colorwheel, it's toast. Replace the colorwheel and you'll be ok
Posted on Dec 18, 2008
I have an rca hdlp6iw51 and i found a color wheel on ebay but i dont know how to change it does anyone have any advice
Follow this steps:
1. Take the back panel off of your set, using your Phillips head screwdriver, to remove any screws. 2. Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further. 3. Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
4. Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 3 Remove the projector lamp. You can reach the color wheel without doing it, but you are less likely to damage the projector lamp if you take it out. Loosen the screws at the base: depending on your DLP's brand, the screws may come out, or may just loosen. If they come out, set them in a safe place before removing the lamp. If not, just pull the entire lamp out, once the screws will not loosen further.
  • 4 Take out the panel that is connected to the cable outlets, using the screwdriver to take out any screws. Pull the panel until the cables, attached from the inside, run out of slack.
  • 5 Remove the screws at the bottom of the panel, in the center, and any screws connecting this panel to the outer case of your DLP. The number and location of these screws will vary depending on your DLP's brand.
  • 6 Pull out the entire center unit, pulling gradually. Then, unplug the power cable from the main set (this is generally blue and brown). Remove the sensor switch and any cables joining the center unit to either side of the set.
  • 7 Take out the plug from the cover of the color wheel. In most brands, it will have a black and blue wire connected to a green circuit board. Then, remove any cables coming out of the wheel. Depending on the brand, the screws may be small enough to require the jeweler's screwdriver.
  • 8 Remove the screws holding the color wheel cover in place. Remove the cover, then take out the screws holding the wheel in place. If tape is holding the wheel, just pull on the wheel until it comes free.
  • 9 Put the new wheel into the slot. You do not want to touch the wheel, or you will blemish it and leave impressions that will be visible when the light shines through it. Re-insert the screws. Then, replace the cover, making sure that the wire jacks are in the same places.
  • 10 Reassemble the DLP television, then plug the set into the wall, and turn on the power.
  • Read more: How to Change a DLP Color Wheel ' eHow.com http://www.ehow.com/how_7697815_change-dlp-color-wheel.html#ixzz1VdDl2OQb
    Aug 21, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
    I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
    Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
    Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
    My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
    Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
    Encompass Parts Distribution 1-800-638-3328
    Samsung Parts.com 1-800-627-4368
    You can also go to Encompass website and look up your Model#
    Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
    Fluid leak and a sqealing noise when turning steering wheel,topped up with fluid and sqealing noise goes away?? but has returned and fluid level seems to be holding.
    look to see if the pulley is coming off the pump and belt is going astray not lining up. also may have air in system jack front end up engine off and turn lock to lock with pump cap off look for air in pump may need assistint to look .
    Aug 10, 2010 | 2005 Ford Focus
    Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
    Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
    May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
    Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
    The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
    Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
    Noise
    Thats the color wheel part number 212184. You can get a new replacement Color wheel for your model at the following link.
    http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-212184/cName/color-wheels
    May 29, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
    Samsung dlp tv hls 5688w problem
    Possibly a bad fan. operate the set for at least an hour to warm it up then shut it off does the noise continue for a moment? If so its probaly the fan for the lamp that is making the noise.
    Mar 20, 2008 | Televison & Video
    Tv intermittenly works
    the squealing is the power supply off frequency its trying to produce b+ voltage there must be something loading down the b+
    Aug 25, 2007 | RCA HD44LPW165 44" Rear Projection HDTV
    RCA HD61LPW165 61" Projection HDTV Logo
    122 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
