Question about Epson Stylus Photo R320 InkJet Printer
Epson R320 printer will not recognize any of the ink cartridges
I replaced all the ink cartridges with genuine Epson ink cartridges, however the printer now gives me the error message "cannot recoginize ink cartridges" and lists all 6. If I remove only 1 of the cartridges, it only gives me the same error message for that cartridge only. I tried putting the old cartridges back in but this made no difference. Any ideas???
thanks, dave
  • 4 more comments
  • mllevendo Dec 29, 2008
  • cactus_jack2 Jan 01, 2009
    My light cyan is giving me the same message.
    Any one know why?
    I use the CIS Epson R320
  • lowie31 Jan 17, 2009
    I have the same problem with my light cyan as well. Tried ssc but no good. Help please!
  • fjhh Feb 08, 2009
    I have just the same problem. just a question, have you had an ink licking out of the cartridge? it is just to guess if the ink can be the reason. Any comment will be helpful. Thanks.
  • Anonymous Mar 16, 2009
    Same issue.
  • Anonymous Apr 09, 2009
    fucjked
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
This is genarally caused by the cheaper ink cartridges construction, where the interface chip is not inserted into the cartridge properly.
Normally just slight pressure on the interface board will re-position it correctly.
Posted on Jul 25, 2009
Epson ink cartridges, always empty?
Epson has gone to great pains to ensure that third-party cartridges dont work. They really did a good job. Sometimes their printers wont even recognize genuine Epson cartridges. I saw a CX8400 with a brand new cartridge claim it was out of cyan ink after printing one 4 x 6 photo. Then it would recognize any cyan cartridge. It had to go back to Epson for replacement. Sign in China com Online Wholesale for AD Signage Product
Apr 22, 2014 | Office Equipment & Supplies
Epson s20 cannot recognize ink cartridges
have you bought genuine ink cartridge?? if it isnt genuine or original the printer wont recognize it at all..
Jun 02, 2010 | Epson Stylus S20 InkJet Photo Printer...
Installed black cartridge correctly printer says does not recognize cartridge
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Photo R320 InkJet Printer
At last changed ink cartridges with make always used now epson are saying dont recognise so now printer not working at all
just try to remove and re-insert the cartridge in a way that you get a click sound in the printer. it means you have done the job completely. (or)
try re-installing the software .
i am assuming you are using the original epson cartridges.
Dec 29, 2009 | Epson Stylus Photo R320 InkJet Printer
I haven't used my epson c84 in a long time. only the yellow in appears on paper. what can be done to get it up and running again?
ink in cartridges tends to dry up if it is un used for a long time, if you see that there are no other problems rather than this then an ink replacement is required get a fresh genuine epson cartridge color and black
Nov 23, 2009 | Epson Stylus Photo R320 InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Jul 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
"Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Jun 26, 2009 | Epson Stylus Photo 950 InkJet Printer
Epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Nov 08, 2008 | Epson Stylus RX580 InkJet Photo Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
1,900 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
