Question about LG WM-2277HW Front Load Washer
Everything works great -until the spin cycle - loud noise
When my machine gets to the spin cycle after it speeds up (about 3-4 minutes in) there is a loud noise that sounds like something is clanking as the drum spins. It is so loud that we can not finish the cycle. It does not sound good. I have taken off the access panel in back and do not see anything. It sounds like the sound is coming from inside the drum casement. Is there a way to access this, or what may be the problem?
  • 32 Answers
Have you checked to make sure all three shocks under the tub are ok?
Posted on Dec 23, 2008
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
2001 Gibson Washing Machine - Front Loader
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 29, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud dry sounding spin cycle
cabrio and calypso have some issues with either main bearing problems or brake drive issues, either or this is an expensive fix, so if you have an extended wty, call your service provider, if not, just replace it, repair most likely in excess of 600.
Jun 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
LG WM-2277HW Front Load Washer Logo
1,159 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
