Question about Audiovox CDM8910WW
Vocfunc.c 02167 error
When i dial out of my phone the screen goes blank with the VOCFUNC.C 02167 message. Then the phone shuts off but restarts on it's own. When some one calls me the phone rings as soon as i flip it open i get the same vocfunc.c 02167 error.
    Problem Solver:
  • 3 Answers
Your phone thinks thinks you are dialing someone
Posted on Apr 18, 2007
SOURCE:
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
How do I fix an error code Oxc0000185 ?
Dial our HP Customer Support Phone Number 1-844-355-5111 for HP Customer Service to fix an error code Oxc0000185. Here with HP Customer Support you will get exclusive HP help,offered by well-trained technicians.
HP Customer Support Phone Number 1 844 355 5111 HP Help
1-844-355-5111 hp customer support phone number-r3jwe4py31xoj0ee0gunh0fe-5-0.jpg
Jul 29, 2014 | Dell Inspiron 13z 5323 Core i5-3317U...
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
Nokia 2630 .The problem is White screen for 2-3 sec. then turn off .Help pls
1. Check the battery. They may be worn out and dead.
2. Next time, your screen goes blank / white, shut off the mobile voluntarily, restart the phone and press reset button.
3. This will fix the problem. Caution: You may lose all your data.
May 15, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
After dialing via Contact, screen will go blank
try taking the battery out wait a couple minutes then put it back in. after this process it should work normaly
Jun 15, 2009 | LG Dare VX9700 Cell Phone
Screen goes blank , is fine when phone re-starts
I had the same problem and sent it to repair : they actually replaced the screen and now don't have this problem anymore.
Jun 10, 2009 | Sony Ericsson G900 Smartphone
Tata indicom dial up instllation problem
donot connect the mobile first , install the software cd included then when prompted connect the phone first to data cable then insert in usb port, follow on screen instructions
Apr 13, 2009 | Computers & Internet
Samsung SGH A117 - Non Functional, after dialing goes blank then restarts
then now you will need to have the phone's firmware reflash into the phone to fix it.
Aug 01, 2008 | Samsung SGH-e315
Audiovox CDM8910WW Logo
37 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
