I NEED NEW SPARK PLUG FOR A REDDY HEATER MODEL R100A
PLEASE LET ME KNOW WHERE I CAN GET A NEW SPARK PLUG FOR THE REDDY HEATER R100A MODEL.
I LIVE IN WASHINGTON STATE BUT COULD ORDER OVER THE INTERNET
THANKS
HERB JOHNSON
  • 8,197 Answers
You can order it from here.
http://www.desatech.com/product.cgi?products=Construction%20Heaters
I would just pull it out and see if you can get at a local auto supply store first.
Good Luck
Posted on Dec 18, 2008
Reddy heater r100a unit comes on app 1 min then turns off tripping reset button
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy heater 100000 btu model r100a. Everytime I plug it up I have to push the reset button. It comes on only for about 30sec. Then the reset will trip back off and it shut down. What could be...
Does the heater light up before it cuts off. If it does, then you need to first clean the flame sensor. It is a photo type sensor. Remove the top from the heater and the flame sensor is a black rubber boot close to the burner. You can clean it with a soft cloth or a cotton swab and some alcohol. If the heat isn't lighting up before the reset trips, with the top off, start the heater and check the igniter. If it is OK look for fuel spraying from the fuel nozzle. Watch out for the fan while the top is off and the heater is on. If fuel isn't spraying out, check the nozzle for clogs and check the fuel filter. Let me know if you need more help and please rate the answer.
nitensheaterservice@earthlink.net
Jan 15, 2011 | Heating & Cooling
I have a Reddy 100,000 btu space heater model R100A. The fan will turn on and the spark plug is igniting, but it does not appear to be getting any fuel so it will not light.
You need to check the nozzle for clogs and also check the fuel filter. Let me know what you find and I will tell you some other things to check.
Dec 29, 2010 | Reddy Heating & Cooling
I have a R100A reddy heater that spits and smokes. Any ideas. I cleaned nozzel and new plug still does it. Thanks
Sounds like it's not getting right amount of fuel. Could be an air leak in pick up tube. Check for stuck vane in pump also.
Jan 22, 2010 | Heating & Cooling
Reddy heater model r100a runs approxamitly 15 to 20 minutes then kicks out.fan seems to run fine and already replaced the spark plug.
generally if a heater with a spark plug will run for 10 minutes or longer then that’s an indication that the electronics are functioning properly, so for now, eliminate "any fuel delivery problems" before trouble shooting the electronics. The spark plug should spark for the duration of the run time. If the flame goes out the heater shuts down (just like its designed to do). Imagine the fumes & danger involved if the heater continued to pump raw fuel into a hot combustion chamber!
Some possibilities:
  1. the plastic end cover is cracked. When the room heats up the crack expands allowing the air pressure to fluctuate.
  2. the air pump pressure is not correct. (instructions at www.reddyparts.com )
  3. the fuel filter is restricted.
  4. the nozzle is restricted or worn.
  5. there is an air leak between the pump & the nozzle.
  6. water in the fuel. When a droplet passes through there is a momentary flameout condition which will cause the photocell to shut the unit down.
  7. The photocell is defective
Some more troubleshooting tips
Mar 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Moter run got spark will not go
Set the pump pressure first, then trooubleshoot to see why there is no ignition. Chances once the pressure is set, the heater will run.
Feb 01, 2009 | Heating & Cooling
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
70,000 BTU Reddy heater - runs - but it puffs smoke
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
