Question about Associated 18T Complete Differential Kit
I have a rumbling noise coming from the front
I have a 1800 vectra p.reg,when i take my foot of the accelerator i get a rumbling noise,but it goes when i accellerate.i have been told it is the diff bearing. can i do this job myself,and is it easy. thanks
    New Friend:
It could possibly be the wheel bearings
Posted on Dec 10, 2013
Rattling noise when accelerating
I would need to know what vehicle this is? 4 Cylinder. V6? 3.0? There are a few things it could be,
If the Engine is Moving, it could be hitting something so I would check the Motor Mounts (Happens quite Frequently on Taurus)
Check the Tension of your Serpentine Belt
Apr 05, 2013 | Ford Fusion Cars & Trucks
Vectra 2.2
Hi my vectra did this and didn't show a fault code it's the crank shaft position sensor located behind the starter motor on the front of the engine the sensor is about 30 pound mines never cut out sins i change my spark plugs and coil pack to trying to figures out who knew it was a little sensor it through a your crank shaft outta wack and it throws through a lot of petrol otta timing cheers scott
Aug 31, 2012 | Vauxhall Vectra Cars & Trucks
Rubbing noise in front end when car sits going over a dip, also when engine is braking, noise comes and goes
most likely you will find that there is a plastic gard up above the tyre. if it has come lose then sometimes one end of it can flop down and rub aainst the tyre. this will usually happen when you go through a dip because the suspension let the tyre go closer to the gard at the same time the plastic bit hangs lower as the car goes through the dip. when my car did this I also found that when I tok my foot off the accelerator the front of the car would drop down causing the suspension to do the same thing as when it goes through a dip. also some corners and and uneven roads do the same thing.
Aug 20, 2012 | 2003 Mitsubishi Eclipse
2003 jetta gls rumble in the front end
sounds like a gearbox bearing ,,,this sounds like a growling noise usually when accelerating although as the problem gets worse it can happen constantly ,,, wheel bearings can growl too but will give a constant noise regardless of acceleration ,,, you need to see to this quickly as the more you drive you will cause more damage and cost to you ,,,,bearings will fix it in the early stages but if more damage is done you could have to pay for new gears and shafts which is expensive
Feb 11, 2012 | 2003 Volkswagen Volkswagen Jetta
Hello all, I've bought a 57 reg V70 that has a rumble coming from the nearside underframe. All suspension bushes, etc. have been check and nothing found wrong. The noise is there all the time, not just on...
first thing to come to mind is a wheel bearing, being a noise that 'rumbles'-jacking it up, one wheel at a time and turning by hand might reveal which wheel is making the noise. Does the noise 'change' with speed, or braking? Noises are tough over the internet, but your description leads me to think they need to be checked first.
Apr 12, 2011 | 2007 Volvo V70
Clicking noise coming from the Engine and car shakes when stoppin
Probably a disc brake pad scraping on a warped rotor as it goes around. When you apply the brakes the warped rotor causes the car to pulse or shake as the rotor goes around and applies the brake unevenly. You need a front brake job.
Nov 10, 2009 | 2002 Nissan Maxima
My car makes a loud rumbling noise when i accelerate and gets louder as i go faster, if i turn my wheel slightly to the left all the noise and vibration stops and it sounds normal again
I believe the bearings in the front wheel are about to come to the end.
Have it checked in a garage.... NOW! otherwise you will be driving on 3 wheels... sooon.
Iceman.
Nov 10, 2009 | 1999 Dodge Stratus
Engine noise
getting good lubrication flow to the top end of the engine ? maybe some lubrication flow is being blocked to the top of the engine and you hear valve system noise.
Jun 17, 2009 | 2006 Suzuki Forenza
Associated 18T Complete Differential Kit Logo
Top Associated Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Associated Toy Expert? Answer questions, earn points and help others
