Question about Belkin Computers & Internet
Setting up wireless network I get message 'limited or no connectivity'. Works ok on 2 computers but not the 3rd. I think I've messed up the network keys. Is is possible to start over again and not have any password on the other 2 computers?
  • 837 Answers
Be sure that TCP/IP settings are all set to auto, shutdown and restart and then try to "surf"
Posted on Dec 18, 2008
Linksys E1000 Wireless Router limited or no connectivity
What is the operating system on your computer?
Are you trying to connect to the wireless network?
on Windows XP computer you will get this message when the computer is not able to connect to the wireless network.
There are 2 reasons. You might have entered incorrect password or your computer is not getting IP address.
Read Limited or no connectivity
Oct 03, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Tip
How to fix limited or no connectivity message with your wireless network...
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
on Nov 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
My connection is saying limited or no connectivity. i know it is not the network because other pcs are able to connect
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Jul 06, 2010 | Computers & Internet
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
Apr 07, 2010 | NetGear WGR614 Wireless Router
When your computer does not get IP address from the router, you get the message " limited or no connectivity ". There might be 2 possible reasons for this . 1) If your wireless network is secured then you are not entering the correct network key. Open the set up page of the router and check the wireless settings of the router .
2 ) Your router is giving the IP address to the rotuer.
Open the set up page of the router and check , the DHCP server is enabled or not ? It should be enabled.
You are entering the corerct network key and DHCP server is enabled, but still getting the same message. Assign a static IP address to the computer.
Click here for more instructions
Mar 29, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
LIMITED OR NO CONNECTIVITY WITH AN EXCELLENT SIGNAL STRENGTH WITH TWO NOTEBOOKS
Wireless connection ...limited connectivity
If you connect the computer to the router , does it works? If the wired is on line that means the wired connection is OK.
just open the router set up page and check the wireless settings.
Feb 28, 2010 | B&G Computers & Internet
Can only get a limited conection on wirless but works fine when connected with cable samsung net book
Jan 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I'm trying to re-confirgure my nephews laptop. He messed up the internet setting for wireless networking. I was thinking of just going ahead Aand erasing everything and re-install WINDOWS xp , But he has...
ok so you are connected to the wifi network. if your wifi is broadcasting internet and you got server nt found errors, it could be a browser problem...also, are there any other computers connected in the same network that can't connect to the internet? if so, then it is a network configuration error
if it is a browser's error, misconfiguration, etc, try to check:
1. right click on the IE's icon on desktop and click properties
2. Go to Connections tab
3. Click on LAN Setting
4. Check "Automatically detect settings
Make sure also that in your browser, you did not check the "Work Offline" option. Look at it at the File menu
Aug 28, 2009 | HP Pavilion dv6000z Notebook
Wireless connection
Check the ip addres of your pc. You might be having an ip of 169.x.x.x(that means limited or no connectivity). If this is the case, you were not able to completely connect to your wireless network because your network is secured. Try to connect to your wireless network again and make sure you enter your correct network key. When you check ip address again you should have an ip of 192.168.x.x(depending on your router's ip)
Mar 13, 2008 | Blitzz Technology Wireless G BWU713...
Computers & Internet Logo
29 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
