Question about Philips 42MF531D 42 in. LCD Television
Pixel emits white light w/flares during certain dark backgrounds
The TV model is an LG50 1080 37' brand new. I had this problem, took the set back to the retailer thinking I had a dead pixel/defective unit, and the 2nd TV has the exact same problem at what looks like the same location on the screen: left side, center vertically, 1/3 of the way in from the edge.
I call it a star because it's a white dot on a dark background. The sales guy said it's definitely NOT the TV but maybe the cable box (Time Warner Cable) or possible the CO AX line has junk on it? Said to try S-Video cable and/or get a new cable box
Many Thanks!
tvtechnician
  • 105 Answers
SOURCE: BLUE LINE
call philips to get this srviced under warranty. this repair might take a few weeks because the failure could essentially be any one of several parts. first thing to try is the ssb, then the logic board and lvds cable. if none of these work then you need a new panel
Posted on Oct 14, 2007
SOURCE: Right third image filled vertical lines when hot
Ive Had the same issue with my TV - and its really dissapointing to see it so well documented - obviously this is a design fault- its the last Philips TV im buying :(
Posted on Jan 13, 2008
  • 22 Answers
SOURCE: Vertical lines down center of Plasma TV
If it was just a vertical black line, i could definitely solve your problem.  However, i would still perform the following fix if i was you.  It worked for me on my gateway plasma.  Go to the following link and read carefully and follow closely!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
ST
Posted on Apr 28, 2009
praky16
  • 744 Answers
SOURCE: I have Philips 42PF9630A that the screen goes to
hi..
I had same problem....Its fixed now working great....had 2 blown capacitors.Cost me two bucks and about an hour to fix.Look at the capacitors on the main power supply they should be flat..
thank u
rate me
Posted on Jul 21, 2009
  • 73 Answers
SOURCE: the tv will not turn on anymore-have a blinking
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Posted on Jan 21, 2010
Can I fix dead pixels on a plasma 3D TV
you can not fix dead pixels on a display panel . however are you sure that its pixels or a lost line coming from one of the buffer boards in your set. you may have a defective buffer board and may not be the panel at all .
Oct 20, 2014 | Televison & Video
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
Nighttime photos have white haze (like a light reflections and not focused
If you have a scratch on the front lens of your camera, this could cause this. Bad light conditions, won't help a camera to autofocus.
But every light that can enter the front lens from a certain angle, can cause flares. Called lens flares. On DSLRs you often see a lens hood that comes with the lens. It is wrong to think you only need them in bright sun light, and put them the wrong way around on your lens. Every light source can cause a flair. So even shooting in the dark, close to a light source a lens hood can help to avoid flares. If you don't have a lens hood, screen the light with your hand.
On Wikipedia, you can read more about lens flares.
I won't tell what brand and what model, but a expensive system camera got white orbs in the picture when shooting in certain (dark) light conditions. So don't think it is only your camera.
Dec 04, 2013 | Galaxy Cameras
Little lights like twinkling stars on my projected pictures
it depends on the brand and model number of your set
Mar 17, 2012 | Televison & Video
Dead pixel
you need to do first is to restore factory settings to fix the problem if it is on the setting..if not helped you only have to do is ask for the replacement to the store/website...that is the only way to solved your problem because I won't give you the solution because it will void a warranty..
Thanks
Feb 03, 2012 | Televison & Video
Hi, I own a 50 inches plasma LG tv (the model is 50pj550) for only 2 weeks and it has started giving me 5 green dotted lines 9consisting of green pixels), from top right corner to bottown left corner....
Sorry to lay some bad news on you.........
It sounds like your set has had defective silk screening during the manufacturing process.
The lines in a plasma set are laid out using a silk screen process, the defects (if any) are burned out by laser, then the surface is sealed to protect the lines with a vacuum coating process. Your set sounds like it had a manufacturing defect that quality control somehow missed...it happens!
The good news is that since your set is brand new, you should be able to exchange it. Don't delay!
Feb 01, 2011 | LG Televison & Video
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Dec 01, 2010 | Televison & Video
A gree speck on the screen
It's an "open" pixel. It is unable to close to block the light, so it appears as a dot. The color white is made up of red, green and blue. So, a single open pixel will have just a single color. If you have had the TV for just a short time (< 30 days), many retailers will exchange the TV. However, if you have had the TV longer, you should contact the manufacture. The pixel specifications will vary from manufacture to manufacture... but some manufactures have a zero dead pixel specification and they will repair the TV at no cost to you. I hope this was helpful, best wishes.
Apr 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips 42MF531D 42 in. LCD Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
