Question about RCA Thomson Digital Cable Modem (DCM305R)
How do I migrate my internet connectivity from an old pc running xp, using isp comcast & Thomson cable modem over to a new pc running vista?
    Genius:
  • 1,605 Answers
NOTHING.
turn off all equipments.
connected the modem to the incoming cable.
use the CAT-5 cable comes with unit, conencted from the one of LAN port to your PC LAN port on the rear panel. turn on the modem then turn on the PC.
you are good to go.
Posted on Dec 30, 2008
I am using windows XP in my Toshiba laptop sattellie Series. I am unable to make any new connection to connect to Internet.
That is because the L300 does not support XP.
If you reinstall Vista, all will be well again.
XP is no longer supported even by Microsoft as it is over 10 years old and now obsolete.
Hope that helps.
Jan 23, 2011 | Toshiba Satellite Pro L300 Notebook
Works with xp computer but cannot get my new vista premium computer to recognise it . I've tried cmd/ipconfig etc but no joy
Turn the modem off.
Turn the modem on.
Try: IPCONFIG /RENEW
to get an IP-address.
Does your Internet Service Provider require you to "register" each computer that you connect to the modem? Obviously, the new computer has a different Ethernet adapter than the old computer.
Thus, the ISP may be allowing _only_ the old Ethernet adapter to be used -- until you contact your ISP.
Sep 14, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Sep 11, 2008 | Computers & Internet
Cannot connect to the internet
Are you running the setup disc provided by comcast to get your email setup?
If you are , you do not really need that disc as it provides useless and often outdated junk on the disc. You should be able to surf the internet by plugging in your Ethernet Cord into the laptop with no problem.
On the issue of the Comcast user name and password, this was originally used at the original configuration of the modem when it is wallgardened.
You can always call Comcast and have then activate the modem for you. You'll need the Mac address at the bottom of your modem to activate it over the phone.
Online Activation usually requires your customer account number. But since it looks like you do not have this data, you will need to call them directly.
Aug 21, 2008 | HP Pavilion dv6000z Notebook
Bought a new computer with vista instead of XP and cannot connect to internet via the ethernet line from my cable modem. what is the secret? Usually plugging it in is enough when I have moved or changed...
Yes! plugging it in on the Ethernet cable on the modem to the computer should get you online. If your not able to get online, you may want to check the following:
1. Make sure that the Ethernet adapter on the computer is enabled. If you can't find the Local Area Connection icon in your Network connections (control panel\network and sharing center), check if the network adapter is properly installed.
2. Some cable service providers require the MAC/Physical address of the Computer to get it online through the modem. If the old computer is working with the modem, you may want to contact your ISP and ask their assistance in getting you online using your new computer.
Aug 02, 2008 | Gateway Computers & Internet
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson Digital Cable Modem (DCM305R) Logo
366 people viewed this question
Top RCA Computers & Internet Experts
Rommel Balcita
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
