Question about Briel Chamonix ES-35 Espresso Machine
Water won't flow through the tubes
Hi. got a used unit from a friend. the water won't flow through the plastic tubes through to the coffee pack although the maching seems to be working. any ideas? thanks.
  • davmon Nov 08, 2007
    Machine will do two pulls and then stops working for several hours. push the brew button and nothing.
  • Robert Doell
    Robert Doell Jan 01, 2009
    I just got a new espresso machine for Xmas to replace our 2 year old Briel - My wife reported that it recently stopped working. With the new model not making coffee as good, I decided to try to fix the old one. I got some hot water and soaked the steamer with it the steamer knob opened up all the way. It seems the steamer had stopped working and so this 'prime the pump' fix would not work. As soon as I got the steamer working the unit started to make coffee again after some pressure noises that sounded like something was clearing out of the system.
  • 32 Answers
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 04, 2008
  • 1 more comment
  • xxpprreessoo Jun 05, 2008
    regarding comment by davmon sounds like you definitely have coffee oil build up. You can try removing the Brew Head Screen and soak it along with the filter basket (if you have the basket with the screw in the middle please take it all apart), soak it in a coffee oil remover (not descaler) from either www.urnex.com or dezcal or another brand. If you have the filter basket with the screw in the middle be careful not to tighten it too tight when putting it back together or that will also constrict the flow again.
    Or you can purchase a new Screen and filter basket at:
    Electra-Craft
    41 Woodbine St
    phone 201-439-1700
    fax 201-439-1701
  • Gillian Zyland Apr 30, 2013
    Fantastic! The Prime-the-Pump solution sounded too easy, but as soon as I stopped the steam then the coffee and tried making coffee again -- PRESTO! Worked perfectly! Thanks so much, xxpprreessoo, for the solution! :)
  • Xochitl Gonzalez
    Xochitl Gonzalez Jul 20, 2014
    Did the PrimeThePump solution on my Briel that wouldn't make expresso and it worked! Just cleaning it, also, after I primed the pump and successfully made espresso, since I think the problem is buildup.
    Problem Solver:
  • 7 Answers
Problem: no water would come out
I posted part of this response in the 'same problem' area for this machine. The 'prime the pump' solution fixed my machine. You must make sure that you open up the steamer knob on top all of the way open and loosen up the steamer nozzle if it is clogged with hot water. Once water and steam is flowing normally again, your machine should resume making coffee the way it was supposed to.
Posted on Jan 01, 2009
    Genius:
  • 1,074 Answers
Take it down and clean it there must be some clogging in the unit.goodluck.
Posted on Mar 30, 2007
How do I empty the water from the main reservoir?
  • Turn off the Keurig coffee maker, and unplug the power cord. Allow the unit to cool for 30 minutes before emptying the water. This gives the water inside the hot water tank an opportunity to cool, helping to prevent accidental scalding when emptying.
  • Pull the lid off the top of the water reservoir. Lift the water reservoir straight up and to the right of the coffee maker. Pour out any remaining water in the reservoir into the sink.
  • Turn the small thumb screw on the back of the Keurig coffee maker counterclockwise with your fingers, and pull off the rear access panel. If the screw is too tight to turn with your fingers, use a flat-head screwdriver to turn the screw. Once you remove the access panel, a tube with a plug on the end is visible. Pull the tube out of the plastic clip holder.
  • Place a large pitcher behind the coffee maker. Hold the end of the tube over the pitcher, and pull the plug out of the tube. Allow the water to drain into the pitcher. If necessary, maneuver the coffee maker to the edge of the counter, and hold the pitcher alongside the counter with the top at counter level.
  • Push the plug back into the end of the tube once no more water drains from the hot water tank. Empty the pitcher of water into the sink, and push the tube back into the plastic clip holder. Position the back access panel onto the coffee maker and secure with the thumb screw knob.
  • How to Empty the Water Reservoir on Keurig Coffee Maker eHow
    Apr 08, 2015 | Keurig B60 Coffee Maker
    Coffee won't come out of the machine, tried cleaning out the tubes but that just made it worse
    You need to advise the model .. but assuming its the CVA 40XX series ... the frist thing to check is the dispenser which has the two pipes comming out of the bottom. This can get coffee residue build up which usually causes 1 or both pipes to have reduced coffee flow. Indication that this is at fault are if the flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can chck this pipework for blocages by openeing door and blowing air though the pipe extending on inside of door. The the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water. If this pipework is not and
    You need to advise the model .. but assuming its the CVA 40XX series ... here is what I would do;
    1. First check is the coffee dispenser on front which has the two pipes coming out of the bottom. This can get coffee residue build up which usually causes one or both pipes to have reduced coffee flow. The indication that this is at fault is if the coffee flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can also check the dispenser for blockages by opening door and blowing air though the pipe extending on inside of the door. The air should flow through easily. If the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water.
    2. Next check the pump and water path. The pump for the coffee is also used for producing hot water. So if the hot water is working normally then you can rule out the pump. If you not getting hot water then its likely to be the pump or a blockage in the flow through water heater.
    3. If above OK then it's a fault with Brew Unit. Follow procedure to remove the brew unit, clean unit and test the air path through both pipes by blowing. Note: When you take out brew unit it not possible to access one of the pipes because its protected by a plastic shield. There is a manual procedure to manipulate the brew unit to expose this pipe so you can blow through it. However the likely cause is not a blockage in these two pipes but the stainless steel filter that the coffee must pass through. You will need an Allen key to remove the bolt holding this in place. Once removed you need to check all holes are free of blockage by inserting a very small wire in each hole. Alternately you can replace this part. If the filter is clogged then you should consider using a different type of coffee as some types coffees cause this problem and others do not.
    I hope this helps. regards
    Mar 24, 2014 | Miele Coffee System
    Coffee water won't flow
    You probably have hard water deposits in the tubing. Run a couple tanks of vinegar through the machine on a brew cycle. Then flush with a couple tanks of water.
    Aug 16, 2012 | Mr. Coffee Bvmcejx33
    Why is my coffeemaker leaking from the bottom?
    1. Make sure the filter is properly in position and that the brew basket is fully closed.
    2. If the coffeemaker is equipped with a removable water reservoir ensure that the reservoir is properly installed.
    3. Avoid overfilling the water reservoir. The coffeemaker is equipped with an overflow slot near the top of the water reservoir. If too much water is added it will flow out of this slot and collect near the base of the unit.
    4. The coffeemaker may require service. Contact an Authorized Service Center.
    Sep 21, 2011 | Philips Senseo HD-7810 Coffee Maker
    Our coffeemaker leaks water from the bottom while brewing
    There are many possible points that the leak can be.
    All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
    You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
    In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
    May 17, 2010 | DeLonghi BCO120T Programmable Espresso /...
    My coffeemaker wont pump water what gives?
    check the plastic tube that runs through the water reservoir. usually when they stop moving water there is a leak or kink in the tube stopping the flow. sometimes they make the tube out of an almost surgical tubing and when the hot water travels through the tube it gets soft and collapses stopping the water. if you have one of the later ones, i suggest taking it back and demending your money back.
    Mar 31, 2010 | Braun Aromaster KF 400 Coffee Maker
    After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
    Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
    Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
    Steam comes from wand when set to dispense water.
    Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
    Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
    Water will not flow
    i had the same problem ran water thru frother for a few minutes then switched back to coffee and water came out the coffee side hope this is helpful
    Jul 20, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
    Water pump does not work
    Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
    Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
    Briel Chamonix ES-35 Espresso Machine Logo
    735 people viewed this question
    Top Briel Coffee Makers & Espresso Machines Experts
    Marvin
    Marvin
    Dennis Fitzsimmons
    Level 1 Expert
    Tom Chichester
    Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
