Question about NetGear WGR614 Router
Please Help! My IP is driving me crazy!
My router AND modem AND computer keeps on aquiring a network adress and the router when connected keeps on disconnecting. It says my password was typed incorrectly/wired adapter isn't detected.
Motorola SB 5100
Netgear WGR614.
HELP ME PLEASE!
Thank you so much!
P.S I want to connect my Wii. Will it work?
  • 1,879 Answers
Modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Posted on Dec 18, 2008
I cant get my ne10 to connect to wifi
Try to reboot BOTH devices, remove power from Both devices and reboot. I'm not sure what a ne10 is? The "aquiring network adress" is it's try to aquire the IP address. If you power everthing down it should reset everything. You question isn't very clear. I don't know what "IT' is? "when i try to connect "it" to my web cube "it" just says aquiring network adress how do i get "it" to work properly please"?
Nov 13, 2012 | Samsung NC10-14GW Notebook
What is it?
default is http://192.168.1.1, but you can check by ip gateway (modem adress), on your computer.
check your local network connection:
if your modem is directly connect your computer, by usb or LAN the gateway adress is the same, you can test if go to the webrowser and type the same adress as before.
Dec 26, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
When trying to connect to my wireless modem it can't get an ip ad
Is it a modem or a router ?
If it is only modem then only 1 computer will go online at a time. If you have any other computer online already then the second computer will not go online and it will not get IP address.
If it is a combination of modem and router OR if it router then you can open the set up page of the device and find out the password.
For this you will need a computer connected to the device.
Check the IP address and open the set up.
Click Here for more info
Nov 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Connectivity
I think you mean that you configured your router at 198.168.254.254
in that case i would go to your network properties of windows.
set a fixed ip of 198.168.254.x (x= anything between 1 and 253)
set your gateway fixed at 198.168.254.254.
then open the explorer and type the adress of your router. Now you should be able to change the ip of your router and if needed enable DHCP.
if you enable dhcp go to your computer and set it do dynamic adress or get adress from dhcp.
or
set your ip settings of your computer as of it was before.
good luck.
Jan 20, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
No ip address from modem to linksys wrt160 n router
1).turn off the modem and the router.disconnected from the Internet ISP. and the computer.
2).disconnect the router from the modem.
3).turn on the modem.
4).connect the router to the modem, and turn on the router.
5).connected the computer to the router, adn turn on the computer.
if you are using wireless, waited about 5 minutes before turning it on.
goto control panel>>wireless network, and configure the wireless seting.
Nov 17, 2008 | Arris Touchstone 450a (CM450) Modem
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Unable to access the router for manual setup
open a web browser and goto http://192.168.1.1 the default password should be admin and the username is admin too
Nov 09, 2007 | NetGear RangeMax WPN824 Router
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
NetGear WGR614 Router Logo
134 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
