Question about Linksys Wireless-G WRT54GS Router (e125894)
I need to recover a WEP key on a Linksys WRT150N Router, I already tryed getting into the http://192.168.1.1. thing, wouldn't let me in with the pass. admin, Help??
  •  C. Dante
    C. Dante May 11, 2010
    Hi uten, hi go-tech,
    I wrote up the same solution you two guys came up with, but two things startled me:
    1. You only need a security key if a computer joins a wireless network for the first time,
    2. how can you forget your router password?
    This question smells a little bit like "How do I crack a WEP key?"
    Therefore my question about the physical access...
  •  C. Dante
    Do you have physical access to your router?
  • 1,879 Answers
Hardwire the computer to the router
reset the router
access config via browser 192.168.1.1
username is blank password is admin
Posted on Dec 18, 2008
  • 162 Answers
Reset the router
default user: (leave it blank) default password : admin
  • 41 Answers
Hi Commewe
You will need to get the crrect password to get in to the web enabled setup. If you don't have the password any more you will have to reset it back to factory default. This is done by pressing the reset button at the back covered with a red plastic tab. Move the tab out of the way and press (with a pen) and hold the reset button in for +/- 20 secconds. You will now be able to login with user=admin and password=admin.
Regards
Go-Tech
I can't find my Linksys information in my computer
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 22, 2011 | Linksys Wireless-N WRT150N Router
I had to reset my Linsys router because I lost my WEP key password and I got a new laptop and Now I am unable to log into the router again.
You can log into your router to obtain the WEP key. Usually if you type 192.168.1.1 into your web browser it will take you to the log in screen for your linksys router. The username will be: admin and the password: admin as long as it was not changed. If that username and password does not work then you will need to reset the router by pressing the reset button on the back of it for 10 seconds and then that username and password should work.
Sep 13, 2010 | Linksys Wireless-N WRT150N Router
I NEED TO KNOW HOW TO SECURE MY LYNKSIS WRT150N
To secure your router wireless signal Your Wireless signal may already be secured by the manufacturer and often the wireless code is printed on a label stuck to the router itself
IF not already set here is how you secure the wireless Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - enter the Router’s default IP address, 192.168.1.1, in the Address field. Press the Enter key. A screen will appear asking you for your User name and Password. Leave the User Name field blank. Enter admin in the Password field. Then click the OK button.
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password.
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
Apr 13, 2010 | Linksys Wireless-N WRT150N Router
Trying to set up hp photosmart 4500 to my hp pavailon desk top, don't know wep key number. i have router model wrt160n.
log in to the router (192.168.1.1) using the Internet Explorer then open the wireless settings look for the security settings on that section you will see the WEP key.
Mar 22, 2009 | Linksys Wireless-N WRT150N Router
Configration wireless linksys
Hi
I would suggest you use WPA instead of WEP if possible.
If you must use wep use 128bit or better.
13key acii example
dbct48v89h1e3
Feb 02, 2009 | Linksys Wireless-N WRT150N Router
No network
The Wireless Security of the router doesn't match your laptop's wireless settings. Make sure you configure the wireless security password correctly on the laptop. If you don't know your wireless password, try these steps:
-Connect your laptop hard wired to the router.
-Open Internet Explorer and on the Address Bard type http://192.168.1.1 press enter.
-It will prompt you for username and password. By default, there's no username and on the password type admin and hit OK. If admin didn't work, type your own password for the router.
-When you get to the Setup page, click on Wireless Tab, then click the sub-tab Wireless Security.
-Look for Security Mode. If Security Mode is WPA-Personal, the Passphrase is the wireless security key that you need to enter on the laptop's wireless settings. If the Security Mode is WEP, the WEP Key 1 is your wireless security key. Connect to the wireless network and type it in. That should solve your wireless connection problem.
Sep 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys access point 54gc
dorn1014:
This WEP key will be the same as you had put into your router. Go into your router like 'http://192.168.x.x' (check the manual of your router it will give you the default ip numbers of your router configuration page. On that configuration page you will find the WEP key. Basically you can also change it from within that page.
Or
If you have already changed the ip address of your router make sure you put instead of the one I mentioned.
Thanks Hope that helped.
Dec 17, 2007 | Linksys WUSB54GC 802.11g/b Wireless...
WEP key
it's impossible for anybody to know your password, you will have to reset the router, normally at the rear of the unit by pushing a pen tip into the hole and start again with no security and then set it up again
Nov 04, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
88 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
