Question about Nvidia GEFORCE 4 MX440se / MX 4000 VIDEO CARD GEFORCE4 64MB TV OUT Graphic Card
Rca tv dispolay is black and white. color?
I have the geforce4 mx4000 set to clone between my monitor and analog tv. picture DOES show on both but tv image is black and white
  • 111 Answers
Windows does not recognize the tv and if you are using a cloned driver it is trying to use the tv with the vid adaptor drivers as the tv drivers you are using the basic generic drivers from MS beacause it does not know what it is download the proper drivers and go from there
Posted on Dec 19, 2008
Firstly, CAN??, and then how do I get an NEC NLT-19XT1 television to work with a TEAC High Definition Digital Receiver HDB848 HDMI, please. Anyone know how? Appreciate all the help I can get. Thank
Id the TV Anolog or Digital? If it is analog, then the digital receiver must have RCA outputs to meet the TV's RCA inputs. To make an old analog TV work (meaning getting a picture), you have to check id the receiver has RCA or S-Video outputs. If so, then connect an RCA cable with yellow into yellow, red into red and white into white and then connect the same colors plugs to the yellow, red and white to the RCA inputs of the TV. Or, you can connect a S-Video cable plugs in the output of the receiver and the input of the TV, disconnect the yellow RCA plugs at both the receiver and TV sockets and leave the red and white cable for sound only, as S-Video has an improved video signal, therefore better picture quality. On the TV you have to select an AV input channel, like AV1 or AV2, etc. The same channels that you had used when you were once watching VCR tapes on analog TV. Hope this helps.
Nov 17, 2014 | Televison & Video
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Nissan Murano monitor not showing in colour
Is there a setting on there where you can change the picture from color to black and white.
Jul 10, 2009 | 2005 Nissan Murano
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Same as other poster: Player only plays black and white
It sounds like the circuitry which actuates the color drives for the screen are not working, this would ba analogous to adjusting for a B&W picture on a color TV you have color but the screen shows black and white. I would get a schematic for this set and measure the voltages on the color processor that connects to the screen since you know that the external jack has color. If possible I can help you troubleshoot this, if you need me to help out.
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Oct 15, 2006 | RCA F27628 27" TV
Computers & Internet Logo
247 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
