Question about Samsung SC-L610 Hi-8 Analog Camcorder
LCD Screen My Lcd screen has gone mostly white, it only shows a third of the picture at the top of the screen. Records and plays back fine through the view finder. Have I accidently clicked something and done this myself or has the camera had it.? Also is it worth getting repaired? Thanks for any help.. KT
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Just buy a new TV, because its costly for repairing
Posted on Jan 03, 2018
Arpi
  • 326 Answers
SOURCE: no visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Posted on Dec 24, 2006
SOURCE: LCD Screen is White
The ribbon cable you require is here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1228041&query=Samsung%20VPD351&model=VPD351&path=98821,112905:98830
Posted on Oct 28, 2007
SOURCE: blank LCD screen
no screen display
Posted on Dec 29, 2008
rjel
  • 56 Answers
SOURCE: my lcd won't display a picture
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Posted on Jun 30, 2009
  • 125 Answers
SOURCE: No picture on LCD screen
Flex wire connecting LCD to the camcorder is broken. I bought it in the repair shop and did it by miself. it's very common problem
Good luck
Meggita
Posted on Sep 25, 2009
Testimonial: "very helpful now ok"
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
My Canon Z25 records fine, but in playback, it only shows about one third of the screen. Then, a different third of the screen will start to play the picture, but the first will stay frozen. It's the...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 18, 2010 | Canon ZR25MC Mini DV Digital Camcorder
My Dell 1521 was working perfectly until this morning. When I tried starting it later today, the LCD screen no longer worked. The top third of the screen is fine. The bottom two thirds are covered by lines...
Your LCD has either gone bad or the ribbon needs to be reseated.
Carefully pry the plastic cover that runs parallel with your LCD. You will see the ribbon to the monitor. Press the connector down and make sure it didn't come loose.
Restart Windows.
If that doesn't work, then you will need to replace the LCD screen. You will not have to replace your lid...just the LCD. That should save you some money.
Hope this helps.
Feb 23, 2010 | Computers & Internet
DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Jun 30, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony DCR-SR42 LCD problem
fp-610 or 1-871-457-21 or old part number 1-871-457-11 is a flexible connector, runs for about $40 with shipping on ebay or web
Apr 26, 2008 | Sony Handycam DCR-SR42 Camcorder
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Samsung SC-L610 Hi-8 Analog Camcorder Logo
47 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
