Question about Acer Aspire L100 PC Desktop
My disc drive is not been detected on my acer l100
I had to reset to the factory setting after a password complication. Can you give me advice ? Thanks
  • V C MICHAEL
    V C MICHAEL May 11, 2010
    did you remove or detach cables from disk drive? see that they are properly installed.
    Problem Solver:
  • 5 Answers
Ensure your cables are fitted correcty and the correct jumper setting ie: master jumper is intalled on the master cable then enter bios and auto detect you ide drives if it finds you disk drive it should be ok if not you may need to change your drive!
Posted on Dec 18, 2008
Reset acer aspire E1-522-3813 to factory settings?
If there is a password set, you cannot reset to factory unless you know it. Use a system disc and start from scratch.
Oct 15, 2014 | Computers & Internet
I'm trying to restore my laptop back to factory settings It's windows 7 the cd disk don't recovery disc don't work IT is a acer
You can reset windows 7 password with Smartkey Windows Password Recovery Enterprise, just need 4 steps to reset lost Windows 7 password.
Step1: Download Windows Password Recovery Enterprise and install on any available PC.
Step2: Burn Windows 7 password reset CD/DVD or USB to reset lost Windows password.
Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive.
Step4. Reset lost Windows 7 password to Re123456 together with the burned CD/DVD or USB Flash Drive.
May 20, 2012 | Acer Computers & Internet
Acer factory reset
First make sure that you back and everything you want backed up, you also remove all componants such as external hardware and usb drives etc, I am not liable for any damages or losses. Just giving info and solutions to your question :D
This is how you do it.
1-Shut down, then restart
2-While restarting hit Alt + F10
Wait a moment while Windows loads the reset files.
3- Select "Restore from the factory default"
4- Click "Next" then "Ok" Then just wait while it restores to it's factory settings.
Jan 07, 2012 | Acer Aspire L100 PC Desktop
Ive forgoten my login password and i dont have a reset disc how can i get back in to my acer aspire l100
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Aug 28, 2011 | Acer Aspire L100 PC Desktop
Hi, I am trying to reset my acer desktop to factory settings. I have tried the acer erecovery management restore and nothing happened. I have also hit delete at startup and clicked "restore default...
You can download the windows installation from the Microsoft website, and run it. Select the Custom Install option to run a Clean Install and select to Reformat the drive, this would clean the drive and reinstall windows, which would reset everything to the factory settings.
That's an alternate route to go if the recovery software on your computer is not functioning properly.
Hope this helps!
Sep 07, 2017 | Acer Aspire L100 PC Desktop
I want to reset it
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Just been given acer5920 how do yo reset it to factory settings
Keep hitting Alt and F10 keys together when it is first booting to get to the restore routine. This can be tricky so give it a few tries. If the restore partition was deleted this won't work and you would need to reinstall from discs to go back to a fresh install.
Aug 26, 2009 | Acer Aspire 5920 AS5920 Notebook
No discs to reset to factory settings
happy to help u .just want to tell u there r no factory settings for windows most options r not changeable.u can aloso try reformatting the system. but if u need to change ur bios setting u just have to press delete or wat ever key u seen on the bios to enter setup. then go to the option load optimised defaults. and u r done. pleasure helping u.
Oct 24, 2008 | Acer Aspire L100 PC Desktop
Won't Power On!
My brother had the same problem with his machine. On doing some research online I came across this site:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390#results
It gave the following 2 solutions to the problem. The first one workedfor a while but then we had to try the second and this seems to havesolved the problem.
Solution 1
ssue
No Power or Will not boot
Solution
If the unit will not turn on and has no power:
  1. Verify that the power cord is plugged both into the unit and an electrical socket.
  2. If it is plugged into a power strip or surge protector verify that the power strip or surge protector is turned on.
  3. Try another power outlet.
  4. Unplugthe power cable from the unit, hold the power button on the unit downfor 30 seconds. Release the power button and plug the power cord backinto the unit. Try to turn it back on.
If the unit has power but does not boot into Windows:
  1. Turn the unit off and unplug the power cord from the unit.
  2. Hold the power button on the unit down for 30 seconds.
  3. Release the power button and plug the power cord back into the unit.
  4. Turn the unit on.
Solution 2
Issue
Recovery media and Restoring a system to factory load
Solution
Acersystems ship with eRecovery Managr, which facilitates the creation ofRecovery media (CDs or DVDs) so the system may be restored to theoriginal load in the event of unrecoverable issues.
How to Make Recovery Media
  1. Click on Start, then All Programs, then Acer Empowering Technology.
  2. Click on Acer eRecovery Management.
  3. If prompted to create a password, create a password and hint.
    Do not lose this password.
    If asked for a password, enter the previously set password.
  4. When the Acer eRecovery Management loads, click the button labeled Burn Disc.
  5. Click Create Factory default disc.
  6. Follow the instructions and put in the required Blank DVD or Blank CD media to make a set of Recovery Media Discs.
How to Recover your system from within Windows
  3. If prompted to create a password, create the password and hint
  4. When the Acer eRecovery Management loads click the button labeled Restore.
  5. Click on Restore system to factory default.
  6. The unit will restart and start the restore.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  7. At the eRecovery Management menu it will ask you how to restore.
    Click on the restore option you would like to use.
How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
We used the recovery from bootup version.
I hope this helps you.
Oct 20, 2008 | Acer Aspire L100 PC Desktop
Acer aspire l100
got a backup disc? you may have created one when you first got your computer?
Jun 26, 2008 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
