Question about Brother MFC 420CN All-In-One InkJet Printer
Scan to computer
I cannot get it to scan to computer, it will print, copy, but not scan to computer.
  • 1 more comment
  • julie123456 Apr 20, 2008
    how do i find out how to use my scanner.  Do i need to connect it to my computer?  It says, "check connection"
  • MS Bking Apr 22, 2008
    I can't scan either. It will copy and print. I get an error message that says cannot find scanner properties. Check connection. I have it connected. How do I install the scanner?
  • julio olazabal Apr 28, 2008
    I can't scan because my computer don't recognize the scanner
Had exactly the same problem after I change my router address. Seems windows is not as clever as you'd think! Goto http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000700/000024/faq000724_000.html?reg=us&c=us_ot&lang=en&prod=mfc420cn_us&Cat=14 which is the Brother USA site and they will step you through the fix. Basicaaly you have to go into control panel, select scanner properties and re-browse the scanner connection. Once it has found it again, you chould be back in business. Good luck Tony
Posted on Jun 01, 2007
SOURCE:
Lexmark s605 won't make a copy
Check settings from computer, try to send command from computer to scan and copy. May have to plug usb cable in to access all settings unless it's wireless only.
Apr 01, 2014 | Lexmark Office Equipment & Supplies
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
I have a Lexmark 7170. I want to print a document from my computer. Unfortunately, when print is selected, the printer will perform as though it is scanning or copying. How can I get it to perform a print?...
Even though the Mode is on Copy on the Printer it would still print if you send a Job from the Computer!
Since When are you facing this trouble?
Whats the Operating System on this Computer?
Aug 06, 2011 | Lexmark X7170 All-In-One InkJet Printer
Well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
Aug 02, 2010 | Office Equipment & Supplies
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer will not print from the computer
its a printer driver issue for me..
I think you need to reinstall your printer driver again..
first you need to uninstall existing printer driver ..and restart your computer ...and then reinstall you printer driver..
why you need to reinstall?
because the printing application for the printer has been corrupt or missing..only the copy and scan application is running properly..
that's why it only scan and copy..but not print some document..
thanks for using FIXYA...
Have a good DAy..ahead^_^
May 24, 2009 | Epson Office Equipment & Supplies
IS IT POSSIBLE TO GET A TEST PRINT OR SCAN TEST WITHOUT THE X1180 BEING CONNECTED TO A PC?
No, if you print or scan, you need always to store the file on a computer, and if you use copy function, you still need the computer, as copy function allowed on this printer is only Colour Copying with PC .
This printer cannot print, scan or copy if it is not connected to a computer.
Oct 10, 2008 | Lexmark Office Equipment & Supplies
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
148 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
