Question about Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range
Frigidaire Range - Oven does not work
I have a Frigidaire Gallery Professional Series Stainless Steel Gas Range. When I try and operate the oven part of cooker, I have to press the "Bake Temp" button. The word 'bake' comes up on the screen along with 3 dashed lines.
I set the temperature using the temp up and down arows, and it shows me the temparature that I have set (i,e. 360C).
However after about 5 secs, the temp on the display changes to 100C and the work "ON" appears in the display, and the oven does not heat up.
The gas hobs work fine, as do the broil part and the Pre-heat function (which is part of the top of the oven), but the part of the oven where the gas comes out does not work.
It has worked before.
I have taken the bottom baffling off to see if there is anything obvious but I can't see anything.
Please can you help?
Many thanks.
  • 1 more comment
  • andymorse_20 Dec 19, 2008
    Thank you TheMobilian.
    The ignitor does not seem to come on and no gas seems to some out. For the boil part of the range cooker, the ignitor seems to glow bright orange, then you can hear the gas start to come out and it ignites.
    For the bottom part the ignitor does not come on at all.
    Do you have any thoughts?
    Many thanks.
  • Anonymous Jan 05, 2009
    I AM HAVING THE EXACT SAME PROBLEM WITH MY FRIGIDAIRE OVEN.
  • rchou May 08, 2009
    Same issue here but broiler works and range top works. Oven just won't ignite. Is there a separate pilot light for it?
  • Frigidaire Master
  • 8,220 Answers
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Posted on Dec 19, 2008
  • Dan Webster
    Dan Webster Dec 19, 2008
    If it was me I would check the ignitor. If you dont' want to spend any money just swap out the broil ignitor and the bake. They are the same.
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
How to remove oven door
Bertazzoni X366GGVX Stainless Steel Gas Range Remove ...
www.fixya.com > ... > Bertazzoni X366GGVX Stainless Steel Gas Range
Bertazzoni X366GGVX Stainless Steel Gas Range"remove oven door" Questions. Question about Frigidaire Kitchen Ranges. 1 Answer ..
Aug 11, 2015 | Bertazzoni Kitchen Ranges
All 5 spark igniters not clicking
Could be range of problems including:
Power not connected/turned off
Ignitor ports clogged
Incorrect operation
Manual is available via Google
Aug 09, 2015 | Frigidaire Gallery FGGF3032MF 30"...
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
I have a frigidaire gallery range that is slow to ignite when the oven is turned on and when it does ignite it"s slow in reaching the set temperature. Also there is a smell of gas.
You would definitely want to seek out a professional technician to diagnose the unit. Gas units are very dangerous if you are not use to working on them. You could have a slow gas connection or flow, a faulty valve, or bad ignition. All would absolutely need a professional to diagnose and repair, this is not a typical DIY job.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
My professional series oven preheats and then stops heating.
HI, there may be some issues within the dual safety gas valves. they mat be malfunctioning. these valves control the gas flow and if the shut prematurely, it will disrupt the heating process. You could also have a sensor issue as well but, im sensing that this abnormal shutdown is being cuased by a fualty Dual oven safety valve assembly.
Please rate and god bless:)
Apr 15, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery Stainless steel convection oven professional series
i have a frigidare gellery oven i cleaned it and now my broiler an oven wont work
Jul 04, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range Logo
1,269 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
