Question about Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Hopefully someone can help me because I don't think Akai support actually exists, I have emailed the 3 listed addresses from differnt email adresses and called and have recieved NO response from them. Although my TV has a wonderful picture I would not reccomend purchasing an Akai. Especially not an open box "deal".
Ok here are my issues:
Akai LCT3285TA
I need a stand/stand mount any suggestions?
Don't have the remote and couldn't get 2 universal ones to work (yes i was using the listed Akai codes).
One set of the component inputs don't work.
Any help will be greatly apprecieated!
Thanks,
-Furstrated with my TV
Any ideas?
Someone please help me.
  • 10,594 Answers
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Posted on Dec 18, 2008
AKAI TV REMOTE CODES FOR COMCAST
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Sep 29, 2009 | Akai LCT3285TA 32 in. LCD Television
My akai lct3285ta wont turn on,the stand by light wont even come on
Hi
Thanks for using FixYa. Make sure the wall outlet is working and the TV is plugged in. Please also check that the remote has fully charged batteries in it. If still the problem persists then unplug the TV from the power out let and again plug it in after five minutes and try to use a different power socket.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Akai LCT3285TA 32 in. LCD Television
Im trying to program my remote for Cable...
Target sells a GE Universal Remote Control, 5 Device with learning feature. Its code for the Akai LCT3285TA is 1139.
Other remotes may use different codes, or have none that will control this TV.
Jan 05, 2009 | Akai LCT3285TA 32 in. LCD Television
Remote code for Akai 37" lcd with Dish Network
Akai support 216-454-0864 .I have the same problem and called the support phone. The answer is this TV came without a code programmed in it.
Aug 17, 2008 | Akai LCT3285TA 32 in. LCD Television
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Universal TV remote control
Target sells a GE Universal Remote Control, 5 Device with learning feature. I can't say if it works with your Verizon DVR, but its code for the Akai LCT3285TA is 1139. If you have the Verizon's remote, you should be able to use the learning function to make the GE control it - that's if the GE doesn't have a built in code that will work for this DVR.
Apr 26, 2008 | Akai LCT3285TA 32 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Remote control code
Manufacturer: Akai
Code(s): 0032, 0092, 0672, 0702, 0812, 1903, 1935
Model: Atlas 1056
Jan 01, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai LCT3285TA 32 in. LCD Television Logo
195 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
