Question about Toshiba 61A60 TV
61a60 Toshiba Flyback
True Story:
I went to Best Buy and bought a new 61" Samsung DLP to replace my 61" Toshiba. I wanted to move the Toshiba into the kids play room. When I got home the TV was on and it was on an input that had a blank screen. (I didn't turn it off) I powered up the device that was connected to that input which was a Digital Entertainment Center by HP. It started up and the screen was mostly blue except the HP startup logo. I walked into the kitchen and a few minutes later I heard a loud click. It sounded like a circular breaker popping. I looked back and the screen was blank and the red power led was blinking. (3 minutes topps it lasted after I bought a new TV).
I pulled the chassis out minus the power board which I left in and checked every fuse, diode, and rectifier and found nothing wrong. I replaced the STK parts and same problem. There was no audio playing at the time. I believe the flyback xformer might have blown, but I'm not sure. There was no smoke, and no burnt smell.
If this is my last hope, where can I find a replacement? I've looked everywhere for the part (Toshiba 23236623 or TFB3086AD) and I can't seem to find one.
Is there anything else that it might be that I am not checking. I looked at everything on the mating board except any small surface mount parts. Also, is there a way I can verify that the flyback is bad? I don't see any bulges, crackes, or burns.
Thanks
  • 1 more comment
  • manders1823 Dec 18, 2008
    I checked F851 and it is not blown. I haven't checked Q863 yet, but I will shortly.
    I had a short on Q404 from Base-Emmitter. I had a feeling it was because of a transformer, so I removed it. Sure enought, it was. I'm not sure if it is good though. When measuring it seems to be an NPN. I get about .560 from B-E, and B-C. But I get about .06 from E-C no matter which way I place the leads on it. Is that normal?
    Thank you so much for your time.
  • manders1823 Dec 19, 2008
    So I pulled up the datasheet and there is a 50 ohm internal resistor which is what I was reading. I had the B-E-C wrong. Now if I power up the TV, the light stays red (HOT removed). I can hear a little hiss from the speakers, but I don't think the amplifier will come off of mute until the picture is up. What comes after the HOT? Is it the flyback?
  • manders1823 Dec 29, 2008
    So I got the new HOT and replaced it. That didn't fix it, but I don't know how I didn't see this before but there is a liquid stain about 5" round right below the blue gun. Could that "POP" sound that I heard when the TV went out may have been the seal blowing for the coolant on the blue tube? Like I said above, the screen was mostly blue when the TV went out. Would a lose of coolant cause the power indicator to blink? Is this repairable?
  • Toshiba Master
  • 5,138 Answers
Check fuse F851 andQ863 then solder all poor solder connections on main board and signal boards.
Posted on Dec 18, 2008
  • ladywinn
    ladywinn Dec 18, 2008
    Hori is surpose to read short base to eimmiter has internal diode,and if you are getting reading on base to collector ,then hori output is ok. But if it reads short also part is bad.
  • ladywinn
    ladywinn Dec 19, 2008
    Replace hori output and see what it does.You should be now to point that its either hori output -flyback transfomer or both. ACME FBT has best prices on them 1yr warranty have number at shop will have to get back to you with number, you can call Electronix Parts or go on line 1-800-233-3205 they may have parts you need.
  • 2,337 Answers
Have you check the HOT Q404?
I would suggest to check that transistor before you decide to replace the flyback. The way to know if you are getting high voltage would be to pay attention for like a charging/discharging static noise when you press the power button to turn the TV ON or OFF.
Let me know if you require further assistance.
  • 1 more comment
  • Jaime Hernandez Dec 18, 2008
    Check this website or contact them to see if they have the flyback in stock.
    You can google for a data sheet for that transistor and you should be able to see all the specs.
  • Jaime Hernandez Dec 30, 2008
    If the coolant leaked onto any electronic parts, that could have damaged the parts where it leaked. I would suggest to clean the assembly with alcohol and a brush to remove the coolant because is highly corrosive and conductive. The POP was cause by the coolant getting into the high voltage area.
Started out with 2 white dots and now have 13 white dots
Sounds like white dot syndrome. Read a article not to long ago on this. Heres a story I found on it good luck (",)
http://abclocal.go.com/kgo/story?section=news/7_on_your_side&id=7795687
Jan 06, 2011 | Samsung 61" Slim-Depth DLP HDTV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
61 in dlp has lines on tv
I have a DLP Samsung 61 inch. It has verticial curved wave lines, these lines seem to move. like it's not on the station good. (These lines are not black, but almost white in color.) All my other TV's in the same house, using the same sat. dish have good pictures. Could you tell me my problem and what part to look for. Thanks
Jul 21, 2009 | Samsung HL-P6163W 61" TV
I am missing red color on my samsung 61" dlp tv
I bought this tv March of 2008, and Feb 2009 light engine went out, confirmed by TV repairman. Went through samsung directly.. WORST COMPANY EVER!!! No longer make this part, took 6 months to tell me that, after order went to 4 different repair companies. Finally, they offered $1770 to replace tv.. and weeks later, received a call that it was not approved so they offerred $1200. Still waiting for this check.. paid $2399 for this tv, still owe $1100!!! Samsung has worst customer service ever and do not stand behind their products. If you find replacement part for this tv, please post.. the part is expected to cost $850 and has to be professionally installed at $300.
Apr 09, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
Aug 15, 2008 | Samsung HLN617W 61" Rear Projection HDTV
DLP 61 inch Samsung Television
Did the technician replace the thermal sensors too? I think there are a few, one is in the color wheel cover. I'd suspect that it could take 40 min. to heat a faulty sensor to the trip point, and that this could make the TV turn the lamp off.
Aug 12, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 61"
I do not have an RCA, I have a Samsung 61" DLP, and the lamp went out.
Jul 03, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Toshiba 61A60 TV Logo
249 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
