Question about Lexmark Optra T612n Laser Printer
How do you replace the bell crank arm on a optra t612
I have some bell crank arms but can't figure out how to get the old bell crank off the shaft.
I'm on my way to change a bellcrank on a t420, simple answer is, you need to cut the old one off.
Be carful not lose any springs though.
Posted on Jun 02, 2009
How do I remove the crank arms
You need a tool like this
Bike Bicycle Cycle Crank Extractor Remover Puller
Sep 23, 2016 | Cycling
96 manual Lantra, trying to separate gearbox to change main oil seal on box. All bolts out but clutch arm goes tight. Tips please ready to burn it.
Somtimes with manual gear boxes the clutch shaft wears in the spigot bearing / bush in the crank shaft or flywheel. It may be necessary to apply force evenly around the bell housing to remove the rust build up on this shaft. If you have a pull type clutch plate ( the only reason for the release arm getting tight) it will be necessary to release this arm from its pivot point first . Check the manual for this proceedure.
Feb 17, 2013 | Cars & Trucks
HOW TO REPLACE HVPS ON OPTRA T612
Please see the attached photo for instructions on how to replace the High Voltage Power Supply for the Optra T Series.
Nov 25, 2012 | Lexmark Optra T612 Laser Printer
Optra T612 fuser replacement
Here's an article in the Lexmark website on How to Replace the Maintenance Kit Parts on an Optra T Laser Printer. Just click on this link: http://bit.ly/95cW2R. Scroll down for the instructions on how to replace the fuser unit. Hope this helps.
Jun 30, 2010 | Lexmark Optra T612 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
What would cause a 900 RIP code on a Lexmark T612?
Go to http://support.lexmark.com/printerfirmware
Locate the appropriate authorization code for your printer model from the following list and enter it:
Optra S (4059) series printers: 4059engn.
Optra T610, Optra T612, Optra T614, Optra T616 printers: optrateng.
Lexmark T520, Lexmark T522, Lexmark T620, and Lexmark T622 printers: lextengn.
Lexmark T630, Lexmark T632, Lexmark T634 printers: e551416.
Lexmark W812: eng204
We recommend you choose to save the file within a directory on your computer's hard drive.
Once it has been saved, go ahead and run the file. The downloaded files are self-extracting ZIP files. Running this file will create a set of .PJL files and a file entitled Readme.1st. The Readme.1st file also contains directions for sending the file over through a parallel connection.
Oct 30, 2009 | Lexmark Optra T612 Laser Printer
When loading paper tray on lexmark optra t614, one sheet of paper comes out of the front. Looks like feed rollers are sitting too low? I dont know what part to buy that will fix it. I guess I could use a...
if the pick wheels are just hanging down you need a bell crank for the auto-compensator this part is 56p1228 turn the printer onto its back this plastic piece is known to break. look to the right its located on the end of the long shaft comming fron the auto compensator and if its broken there should be a spring either in the tray of still hanging from the mount
Oct 28, 2009 | Lexmark Optra T614 Laser Printer
Small plastic piece that holds spring on paper feed in main paper tray broke. Need replacement part or service.
lemark calls this the bell crank ofr the autocompensator 56p1331 lexmark want 27.00 use l-tech4u.com you can get one for 7.00 delivered email for parts not posted
Sep 24, 2009 | Lexmark Optra T612 Laser Printer
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
Lexmark Optra T612n Laser Printer Logo
156 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
