Question about Panasonic DMR-ES30VEBS
Power problem Hello, This panasonic dvd/video recorder was powering itself on and off and is now completely dead. I checked fuse and a is ok. Is this worth repairing?? the machine is only 13 months old.
  • REIDY414 Feb 16, 2008
    HI GOT THE SAME PROBLEM , KEEPS TURNING ON AND OFF ABOUT 3 DAYS INTERVAL TO START WITH THEN DOWN TO EVERY 2 MIN`S AND NOW TOTALY DEAD.... HELP ...
    Genius:
  • 1,074 Answers
Yes it is worth repairing take it to a tech the problem is in the power supply,goodluck.
Posted on Mar 30, 2007
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
I have a Panasonic DVD Recorder DMR-ES10 that will not power up. Are their any fuses on this unit?
hi,
every electronic equipments comes with fuse in the input side for protection .ur dvds power supply may have some problem. check it before inserting the fuse.
ok
Dec 17, 2010 | Panasonic DMR-ES10 DVD Recorder
Power supplierd but does not start recorder no
Hello:
If the unit is competely dead, then you may of blown a fuse or the power supply has failed in the unit. If you take off the top of the unit while unpluged check the fuses near where the power cord attaches to the inside of the unit this is the power supply area, If you have indicators lit or the display is coming on then the unit may have a bad power supply or the System control board has failed. It which case its cheaper to just purchase a new unit.
Jul 14, 2010 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd video recorder dmr-e85h is dead
I had same problem. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
Good luck.
Also for those interested, I found the "commands" listed on http://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h to correct problems.
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
My dvd player is dead.
You check the SMPS (Power Supply Section) and verify the voltages from the various terminals of the transformer accordingly check the bridge, voltage regulator, and filter circuits. If any of this parts are gone replace the appropriate parts not the all.
Jul 25, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Panasonic DMR-ES10
std by light is on?means red light is on.If not than check fuse,vdr,and regulator ic in power unit.if fuse is open than change these component because fuse will blow if the regulator ic is faulty.
Dec 15, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
