Question about Panasonic PT-52LCX65 44" HDTV
Pt-52lcx65 52 in.
My tv has colored spots and the screen has moved to the left from center
Call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Posted on Jan 04, 2009
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
