Question about Panasonic Lumix DMC-FZ10 Digital Camera
Using a sdhc card in a Panasonic DMC-FZ10
SD card works fine. Is there a way to use a SDHC card. I keep getting a "memory card error' message. Thought maybe there is an upgrade I can install to get it to work? Thanks, Barry
  • bfbarnes Dec 19, 2008
    I could not find the firmware update online. Does anyone have a link to it? thanks!
  • ppc210 Jan 23, 2009
    I have a new 8G SD card that does not work in the DMC FZ10. How I can get an updated firmware version
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Posted on Jul 16, 2009
  • 26 Answers
You need firware update for this model ,good luck
Posted on Dec 18, 2008
Can a panasonic dmc-fx8 use a sdhc memory card
This camera cannot be upgraded to read SDHC cards. The maximum is 2Gb Secure Digital.
Sep 18, 2014 | Panasonic Lumix DMC-FX8 Digital Camera
I own a Panasonic Lumix DMC-FZ10, but have never been able to use it because of a 'memory card error'. the camera is brand new. despite trying other SD cards, i an unable to shift this error. any...
This camera should be able to use any SD card of 1GB or less capacity. If you have been trying to use larger capacity cards, that will be your problem (larger cards are actually SDHC, which fit the same slot but are different electrically). If the cards you have been trying are smaller than that, then there is most likely a fault.
These cameras come with a memory card that will work with them (it is very small capacity). If you have tried to use that one and it won't work, then return the camera under warranty.
Dec 25, 2010 | Panasonic Lumix DMC-FZ10 Digital Camera
I purchased a sdhc 4gb memory card for my Panasonic DMC-LZ2 Camara and when I put it in I get a message that says memory card error. Do I need to format it? and how do I do that
The DMC-LZ2 uses SD and MMC cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You will need to use SD cards 2GB and smaller.
Dec 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic DMC--LZ2 gives me ''memory card error'' message if i put a SanDisk SDHC 4GB card in.
The DMC-LZ2 is specified to work with SD cards, not SDHC cards. While SDHC cards are physically compatible with SD cards, they will not work in SD devices. SD cards will work in SDHC devices, but that doesn't help you any here.
It's a hardware incompatibility. No firmware update can get around it.
Apr 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Nov 21, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
1,279 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
