Question about Motorola Mobility H700 Wireless Headset
Setting up device on computer and using with Skpe
I have been able to get the headset into pairing mode and install it on the computer. But when I go to control panel-Bluetooth devices-Motorola H700-services, no services are listed for the device. When I try to set up Sounds and Audio Devices, Bluetooth is not an option listed under Sound playback, Voice playback, etc. Under Sounds and Audio-Devices, no bluetooth devices or drivers are listed. Same problem in Skype, Bluetooth does not come up as an option to select for audio. When I installed the headset on the computer I set passkey enabled 0000.
  • Anonymous Jul 17, 2008
    exact same problem
  • 287 Answers
SOURCE: Motorola H700 not connecting to nokia 6300
The factory code is 0000
Is there an error?
Enasure you are doing the pairing correctly
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator ight becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Posted on Jul 03, 2008
Yazz226
  • 497 Answers
SOURCE: How to pair up headset with cell phone?
first ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
Posted on Jul 16, 2008
SOURCE: Pairing Motorola H700
The Default Key is 0000
Posted on Nov 04, 2008
  • 23 Answers
SOURCE: pairing my blackberry curve8310 to a motorola H700 headset
when pairing a handsfree device to your phone the typicaly generic passcode is 4 zero's (0000)
Posted on Mar 12, 2009
  • 65 Answers
SOURCE: I am trying to pair my motorola h700 bluetooth
When it asks for the passkey, use 0000. that is four zeros. It should then accept it.
Posted on Jul 27, 2009
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
Tip
How to pair your Bluetooth headset with discovery mode and pin
Can't find your bluetooth headset listed on the device you want to pair it with? Don't know your pairing pin? Then this tips for you.
Before you can pair your bluetooth headset with your cellphone, computer, car or what have you, you must put the headset into "discovery" or "pairing" mode. This is done in a number of ways depending on what headset model you have. The most common method is to hold down the main button until the light stays solid blue. Another method is to hold the volume up and volume down buttons at the same time to that end. There are only so many buttons on a bluetooth headset, so you'll probably succeed with a little trial and error, but if not, check with your manufacturers support site.
Once your headset is in pairing mode, you'll only have 1 minute or so to pair it with your device, so have it ready. To do this on most phones, go to the bluetooth settings and select "search for new device" or "add bluetooth device" or something along those lines. Once you've found that screen, and once your headset is in discovery mode, the name of your bluetooth headset should appear. Select it.
The device you wish to pair to will now prompt you for a pass key, so here it is: for almost all bluetooth headsets, the key is "0000." I've also heard of a few that respond to "1234"
And that's it! Your all set. Alright, I hope this helps people.
-Kyle Brownell
on Mar 26, 2010 | Radio Communications
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I am trying to pair my Plantronics Explorer 220 ear piece to my samsung At&t cell phone, It can not find the passcode # 0000,1111,9999 or 1234. Is there another code i can use?
Step One:
Prepare Phone-
Turn on Bluetooth
(Or see the user guide for your
phone.)
SETTINGS
Time and Date
Phone Settings
Bluetooth
Sound Settings
Network Services
Security
Reset Settings
BLUETOOTH
Discover/
Search
BLUETOOTH
220Plantronics
Headset Passkey
PASSKEY
0000
Step Two:
Prepare Headset-
Pairing Mode
for 2 seconds until the light flashes
and blue.
Step Three:
Pairing-
For passkey enter 0000. Headset
and ready to use.
another device, follow pairing instructions on the next page.
Apr 20, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Where can I get a free download for the installer of my Motorola H710 Bluetooth headset
I don't think it comes with an installer. Instead, follow these instructions from eHow.com
1. Charge the headset for two hours before attempting to pair it.
2. Set the headset into pairing mode by opening the microphone. It will automatically go into pairing mode if it is the first time you are using the headset.
3. Set your phone into discovery mode by opening your Bluetooth settings and choosing to "Add" or "Search" for new devices.
4. Choose "Motorola H710" from the list of devices and enter the passkey, "0000," to complete the setup.
Mar 06, 2011 | Motorola Computers & Internet
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
Feb 05, 2010 | Samsung WEP500 Wireless Headset
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
Motorola Mobility H700 Wireless Headset Logo
180 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
