Question about Whirlpool Refrigerators
Referator doors are hard to open
Side by side doors. One has to pull very hard to open either of the doors. How can this be corrected?
  • jmroth36 Dec 24, 2008
    Great advice. It was simple and straight forward, and best of all, it worked. I placed the popcicle sticks on the bottom of the door instead of the seal. This was more acceptable to my wife. By doing this no one could see the sticks. Thanks again!
    JR
    Scholar:
  • 62 Answers
When you shut the door there is a vacuum occuring and causing the doors to be hard to open. Take someting like a popcicle stick, break it in half and put them together, one on the other and tape it to the gasket at the bottom of the ref side door. This will make a vacuum break and should make the doors easier to open. Also, make sure your gaskets are clean, no sticky stuff on them or the frame.
Posted on Dec 18, 2008
When I try to open the door, the garage door will only open approximately 4 inches. Then when I try to close the door, the door closes...then opens to the 4 inch mark and remains here. The 'right' side...
Sounds like a door problem not an opener problem. Pull the emergency release on the opener and make sure the door itself is operating correctly. Soulds like the assist on the door needs adjusted.
Feb 20, 2011 | Garden
Refrigerator door won't stay closed
Pull on the gaskets some times they are broken and will take up moore room that when correctly aligned. especially on the side of the door where the hinges are. Inspect thehinges also see of brackets are loose. If the gasket is bunched up on the hinge side try duct taping them down and retry the door. If this corrects problem replace door gaskets. If a plastic grommet is missing in the door it will nolt align correctly and you will be able to pick up on the outer corner of the door and it will wobel and be loose on the hinge. ReplACE THE GROMETS and retest and align as nessary.
Jun 19, 2009 | Refrigerators
Driver side door won't open from the inside.
remove the inside door panel reach inside and, reattach the clip to the inside door lever rod
May 22, 2009 | HP Compaq Presario V5204nr Notebook
Hard shutting door - will come open easy
Check on the hinge side of the door, often the gasket does not fit properly if the door is not correctly aligned and the gasket ends up bending and preventing the door from closing.
Mar 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
I have a 99 528i, driver side door won't open from inside or out.
to be honest i would need the car in front of me to diagnose correctly but from the sound of it the mechanism inside the door is worn,the lever that springs open the jaws has worn to the extent that it will not push the two contacts inside the lock open to allow the door pawl to swivel around releasing the door.Only way is too remove the door trim if you can and operate the mechanism with a big screwdriver to open the door then renew the mechanism
Mar 08, 2009 | 2008 BMW 528i Sedan
I have a ARS2464B SIDE BY SIDE AND THE REFERATOR SIDE IS NOT COOLING.
unit not going through defrost cycle. build up of frost on rear panel and evaporator in freezer section. check defrost timer, defrost thermostat and defrost heater
Jan 06, 2009 | Amana ARS2464B Side by Side Refrigerator
SIDE BY SIDE FRIDGE DOORS VERY HARD TO OPEN
its because the door seals are new and are working correctly. The pressure difference between the warm outside and the cold inside cause a sort of vaccum and so makes it hard to open. It is usually only after the door has been closed a while that it will be hard to open. put your finger around the edge of the door and shift the seal slightly, this will release the vaccum and let the door open normally. It will get better after a few weeks. I have had 2 whirlpools also and this has been the same on both of mine.
Mar 18, 2008 | Refrigerators
Oven door came off
open the door on the hook that's still engaged look in the slot you will see a hinge lock using a small screw driver flip it back to lock the hinge then let the door up til the door engages the hinge lock grasp the door on either side and lift up and back to take the door off then pull the other hinge out till you can lock it then grasp both sides put the hinge hooks on the pins in the slot open the door all the way and fold the locks back in the body of the range and close the door
Feb 13, 2008 | Frigidaire FEF376 Electric Kitchen Range
Ice door opener
GE side x side GSS22SGMC stainless steelJust fixed my own problem of jammed ice door. 1. pull the light switch plate off (just under the front bottom edge, push through the holes, pull) 2. unscrew the dispenser assembly, 4 screws, pull the unit out  3. WR62X10020 SOLENOID is in the upper right, unplug the black wires from the board. 4. unscrew the right screw from the door-stop assembly (above the ice door)- pull the plastic out of the solenoid piston 4. unscrew solenoid, 3 screws, from back 5. pull the piston, scrape-sand-file off all rust, then lube with oil 6. scrape off rust from inside,  solenoid with shoving steel wool-file-degreaser to get off rust, then lube 7. reassemble, WORKS!! 8. save 35.00 for new solenoid 9. save repair cost of whole new door (happened!) good luck
Feb 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
517 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
