Question about Aiwa HV-FX7000 VHS VCR
Aiwa vcr HV-FX 7800k
Please tell me that a HV-FX 7800k vcr have two FF and REW speeds during playback (this means that the speeds changes when << and >> buttons are pushed once or twice during playback) Thanks in advance, Best regards Radu Fumarel rfumarel@hotmail.com
    Novelist:
    Champion:
  • 275 Answers
If you are asking 'why ' does this VCR have 2 speeds, it is to help you locate a certain portion of the movie fast. If you are asking 'Does' this VCR have 2 speeds, the answer is YES.
Posted on Mar 29, 2007
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a aiwa HV-MX100u there is in need of service. I live in Abbotsford B.C. Canada, can you advice for a service center please.
You can contact nearest Sony service center for Aiwa unit service because Aiwa brand has been owned by Sony and providing service/ repair.
Hope this info will help you.
Thanks.
Nov 09, 2010 | Aiwa HV-MX100 VHS VCR
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
Sony SLV-N71 VCR makes a rattling sound (ff, rew)
I make no claim to being any kind of an expert techie but it sounds to me like there are one or more loose or badly worn parts inside your machine. If you haven't had a look at the innards, try that. Loose things can usually be re-secured and, sometimes, worn parts can be replaced.
Rod
srives@shaw.ca
Feb 04, 2009 | Sony SLV-N71 VCR
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Lost manual
how do i unlock the pin code? aiwa fx7500k
Oct 01, 2008 | Aiwa HV-FX7000 VHS VCR
NO VCR MANUAL
I have no solution, but have the same problem: NO Manual for my /hv-BR 5000 BH VCR. Can anybody help?
Sep 21, 2008 | Aiwa Televison & Video
Aiwa HV-MX100 multiformat VCR won't power on...
Too little information to give any information / help / opinion. What actually happens? Does the Display come on properly? Do you hear any mechanical Noises? Like a motor whirring? Are you able to load a cassette into the machine? Does it get ejected automatically? As you say that the machine switches ON, I assume tyhat the Power supply cicuits are Ok, and this leaves us with the possibility that there is a mechanical problem.Is it that the machine was not used for a long operiod of months or years? If that is the case, in all probability the belts are damaged / broken / loose. I really need more info, please.
Mar 07, 2007 | Aiwa HV-MX100 VHS VCR
Aiwa HV-FX7000 VHS VCR Logo
476 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
