Question about Bemis 4D7-800 Humidifier
Water Wheel won't keep turning
I purchased an old Bemis Humidifier and have been cleaning it ALL day! I have it spotless, put a new filter on the wheel, and started it up. Everything works great, except the wheel stops turning sporadically. There are two smaller wheels that the main drum hangs from (into the water). One small wheel is connected to the motor and turns the drum. The other seems to just be there for balance. When the drum (larger wheel) stops turning, I checked to see if the drive wheel was still turning . . . it was. I have checked, cleaned, and lubed both little wheels. I cannot see where it is getting hung up. Any helpful advice? Is there something I could put on the drive wheel to make it grip better?
Replace the Idler and drive wheel. Even if it looks good the grove in the wheels get deeper over time until they don't work anymore. In a pinch a rubber band or two doubled up in the grove will make it work till you get the parts. Clean and replace the rim of the wheel once a year, replace the wheels once every few years and the thing will last 20+ years. The real reason they don't make them like this anymore is they would be missing out on the income of selling everyone wicks all the time. It's a far superior design. I kept a few of them running for my parents for years. I'm watching for one for my house, I'd pay tripple the cost of a modern new one for one of these in decent condition.
Posted on Feb 01, 2010
This humifier has a black drive wheel and a white idler wheel. On mine, the idler wheel froze up which caused the drive wheel to damage itself trying to turn the drum. First, free up the idler wheel and replace the shaft it rotates on. The idler wheel is still available but you'll have to fabricate the shaft using a machine screw and hollow shaft from your local hardware store. When the idler wheel turns freely, the drive wheel (if still in decent shape) can do its job of turning the drum. If not, you can replace the drive wheel (also still available). I recently put a small rubber band in the groove of the drive wheel and it enabled it to get the necessary grip on the drum.
It's getting harder and harder to keep these wonderful Bemis water Wheel humidifiers alive as the years go by. I wish they still made them because no other humidifier comes close.
Rick
Posted on Jan 31, 2009
  • 69 Answers
That is a common problem and why those type of humidifiers have been discontinueed. Sorry
Posted on Dec 21, 2008
I have Bemis (Esswick) Humidifier Model # 4968. The motor runs fines however I can't get the humidity in my above 30%. I changed the filter and it was close to 45% for a few days but running continuously,...
You should be able to get a higher humidity rate at normal settings. If you want high humidity above 40% that should be easily done with the high speed operation. The unit may need a good internal cleaning, and use a Vinegar solution to clear any Calcium or other mineral deposits from the misting ports and misting elements. You must use only Distilled or Filtered water, not tap water.
Jan 29, 2018 | KwikFilters.com Bemis 4968 Humidifier Wick...
I have a Bemis Humidifier, Model 821 000. I just put in a new filter and dusted the fan blades as best I could. Now the sensor seems to be off kilter. I set it to 45% humidity, and it doesn't cut off,...
MORE INFO HERE THAN THE BOOK SAYS
1. The sensor is capable of picking up the moisture in the air 2. The sensor is normally built in to these items and you can change the filter with no results 3. These units are designed for much smaller areas in terms of the dehumid. features although advertisements say different 4. Whe3n you cleaned your screen filter, ensure you run water through the same filter for best results
Jan 24, 2011 | Bemis 826 800 Humidifier
My unit has a new filter, all parts seem to be in place, it has filled with water. It does not turn on no matter how high I turn the humidistat.
is the water fill rod in place with float attached, and the opposit end in the switch hole? does the humidistat clik on and off when turned (just clik) put your finger or a pencil in the hole on the underside and try again. its prolly the float poor design...
Oct 28, 2010 | Bemis H12 300 Humidifier
Broken fan blade on the 697400 humidifier
Hay Richard -- Little suckers spin to fast for gluing. Take the fan blade off , mark one side before you remove it ex: put an x on the side that is facing the wall. Take blade to a Johnstone supply house. Should be one near you somewhere, they are national. The guys there are usually very good at matching up fan blades. Make sure you keep the one you have with the mark on it. When you get home install the new blade the with the side out that was on the old blade. Hope that helps
Mar 05, 2009 | Bemis 697 400 Humidifier
Not enough humidity
thanks for your question,
seems to me you have a calcium build up inside the unit, something has slowed down the humidification process and that would be the most likely cause, you should run some diluted (CLR) through it and this should take care of the build up, leave it set for a while with the diluted solution in it then drain it out, and refill, give that a try and it should help, also check to make sure the fan is not getting cloged with dust and clean that too, thanks again for your question, please let us know how we did,
mr.grzz
Jan 22, 2009 | Bemis 427 300 Humidifier
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Bemis Water Wick 6974Tanks will not disperse water properly
sounds like new caps should solve it, but have you tried soaking the old caps in vinegar overnight? these guys are not the only ones, but they have the correct caps in stock at a pretty good price http://www.marbeck.com/humidifier_parts_bemis.html hope this helps :)
Mar 14, 2007 | Bemis 697 400 Humidifier
Bemis 4D7-800 Humidifier Logo
1,137 people viewed this question
Top Bemis Humidifiers Experts
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
