Question about Fahrenheat LFP6152 Halogen Baseboard Heater
I have a fahrenheat lfp 6152 heater smells like plastic buening and is very hot on the backsideof unit near the control end. Unit seems to be all on or all both red and orange lites..I need a phone number to call for help
Greetings, I have the same problem. There is a one inch square diode with 5-prong connections held on the control end by a screw on the unit's back. That's where my burning smell and very hot area were located. Call Carrol Apl. 1-800-654-3545. They have the diode for $9 + $9.95 postage. Matt who works there knows the part. Problem must be widespread - China Mfr.= Garbage products and No US Jobs.
Posted on Dec 20, 2008
  • 1 more comment
  • mutley875 Dec 07, 2010
    I just had the same problem last night and the back became hot and today the screw area has a black circle and shorted out the fuse box. Is there a place in Michigan/
  • PilotLee Jan 29, 2011
    I have the same problem. I bought the diode but need to see a wiring diagram for where the wires plug on. Thanks
  • Roger Lookabaugh Apr 09, 2014
    I see where link below for pdf doesn't work. Google LFP 6152-Amazon S3 Manual with wiring diagram and part numbers are there. My heater just starting smelling like plastic burning with both orange and red lights on at same time.
  • 24 Answers
Last time i came across this the limit safety had melted. It is located in the panel right side of the unit. UNPLUG POWER before taking anything apart. You can contact the manufacturer to try to get parts to replace, do not use this heater until it is repaired it can cause a fire
Posted on Dec 18, 2008
    New Friend:
I also had this diode stop working so that both lights stayed on and had the strong burning plastic smell. After searching many places online, I found many places carrying the exact same part. Here's a website containing the specs for the diode http://www.futurlec.com/Diodes/MB2510.shtml, and the site (www.futurlec.com) had the part "MB 2510" for 2.60 with $4.00 shipping. I bought two.
Posted on Jan 13, 2013
I just bought a new Samsung fridge and the side are hot and it also smells like burning plastic is there any problem?please help
The sides are hot probably due to the operation of the moisture control system heaters. These heaters operate to prevent moisture accumulation on the box due to humid air in the space where the unit is located. If you live in a cooler climate, you may not need for these heaters to operate. Not sure about the burning plastic smell.
Apr 19, 2015 | Samsung Refrigerators
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
Chemical smell
Might be Plastic part is Melting due to Heating Element or a Burning Wire might cause Such Smell.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Fahrenheat Electric Hydronic Baseboard...
Add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Smells like burn't plastic.
This is for the LFP6152E electric heater. I called tech support (800.642.HEAT), and explained the problem. I was told it was a diode that went bad, and they're sending me a repair kit. I guess I'll keep this number handy for the next few years.
Nov 09, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Hot electrical smell
Before you open the the unit check first the warranty period /if open the unit the warranty will be cancelled .
The heat sensor not working in automatic / the heat exceed the limit by the heating machine the insulation keep smelling .
The small contactor might stuck due to spark and then stick together , /need to replace contactor .
Jan 09, 2008 | Fahrenheat LFP6152 Halogen Baseboard...
Smell
the heat may be affecting the unit's paint. normally the oil used in manufacturing burns off the first time the unit is used. maybe the proximity of the element to the case is too close.
Dec 19, 2007 | Fahrenheat Electric Convector Baseboard...
Sizzling, burning smell, parts
I have had this problem in the past, its the diode part #160-2000-000 Got the part through Carrol Apl. 1-800-654-3545
Nov 04, 2007 | Fahrenheat PHH15002 Oil Filled Baseboard...
Fahrenheat LFP6152 Halogen Baseboard Heater Logo
1,011 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
