Question about Logitech X-230 Computer Speakers
LOgitech x230 - problems with sound
The speakers work fine on another pc, however when trying to connect to my pc it gives weird noises ...sometimes screeching, other times scratchy and buzzy. It's the same issue in both the rear and front output, and it is in the correct output.
Please help
  • 3 Answers
Check there are no lose connections such as the jack not being inserted correctly or a defective plug
Posted on Nov 01, 2010
  • 55 Answers
If the sound only happens when sound is being played through them I would check the shielding on your connections to your sound card. Make sure that any protective coverings are in place and that the connections are tight.
If it happens at random times even when sound is not being played through them I would see if you are picking up interference such as a close cell phone, fan, ham radio operator, etc.
Posted on Dec 19, 2008
Schematics for logitech x230 speakers
Hey Jaime,
Unfortunately, Dell does not have any available schematics for wiring the x230 speakers available. You would have to maybe contact Logitech.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 06, 2014 | Dell Dimension 2350 PC Desktop
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
How do i connect my logic speakers x230 to my pc with windows xp
Connect 3.5 mm Jack to the Line out port & get connected your speakers to PC.
Thanks.
Happy to help you.
Apr 24, 2010 | Logitech X-230 Computer Speakers
Im trying to install Logitech x230 (windows 7). Have folowed all the instructions but there is no sound. I get a pop up and have to choose between line in, etc..which do I choose? Thanks
Please find or download logitech installer in your PC . Check also the pin connection of your hardware at the back of the CPU usually the phone jack there is lighth green.
Jan 28, 2010 | Logitech X-230 Computer Speakers
Tried to connect to samsung lcd no sound
Plug the green lead on the speakers into the headphone socket on the television. You may need to go into the menu to turn up the headphone output. Turn it to 70% on the TV, then use the volume control on the speakers
Jan 10, 2010 | Logitech X-230 Computer Speakers
My x230 wont work it work for a min then cut out and dont work!!!
Try and twist the jack which is connected to your PC, the solder inside could have snapped. If it has a diferent pwer source for the sound system, then power on, hold the jack and short the ends with your fingertips. If the speakers dont respond then its not getting any power, which could be simple loose connection too. Test both and then decide. If you dont have the correct driver then download from: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q........sodeep
Feb 23, 2009 | Logitech X-230 Computer Speakers
Crap sound, subwoofer no longer working
Guys try to reinstall your audio drivers, because i had the same exact problem, so find out what sounds card you have and go on their website and download the latest sound card driver
Mar 03, 2008 | Logitech X-230 Computer Speakers
Logitech x230 speakers
Reinstall sound card drivers.
Jan 11, 2007 | Logitech X-230 Computer Speakers
Logitech X-230 Computer Speakers Logo
259 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
