Question about Dryers
My Indesit IS70C is only blowing cold air. It was fine this morning. Do we have to remove the silver back to get to the thermostat?
  • 3,463 Answers
Remove the lower rear panel, there you will see the heater element and thermostats, make sure the heater is o/k, and replace both stats.
Plz rate my solution
Thanks.
Posted on Dec 18, 2008
This indesit reverse action dryer (1S31V) has stopped blowing out hot air. I took the back off and cleaned the fluff which had clearly caused the problem. Is there a thermostat or fuse that I need to...
Hi. I have a Hotpoint tumble condensing drier which had the same problem. The solution for me was to access the heating element at the back which involved taking the back off and locating the small metal thermostat which is the size of a two pence coin and 10mm thick.There
is a small hole in the centre and all I had to do was press a fairly thick needle into the hole until there was a click which reset the
thermostat and everything was working fine. This problem does still occur now and again. By the way the heating element is attached
to the removed back with cables giving a clue which helped me find
the unit. Hope this helps Regards Peter
Feb 11, 2013 | Dryers
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
My heating elerment is notworking
The element itself is bad, or it's A bad:
-Thermal cut-off
-Fuse
OR
-Thermostat
May 12, 2012 | Indesit IS70C Electric Dryer
Is70c indesit condenser blowing cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]][
Aug 10, 2011 | Dryers
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
How can i fix my indesit is70c tumble dryer? my indesit is70c tumble dryer wont heat up during performance
open the back panel , not the the full back just the smaller panel located near the bottom half.
the termo will be screwed onto this panel . unscrew and you will see two circles near the top one will have a small pin hole in it . stick a pin in till you hear a click replace and should work fine
Mar 05, 2010 | Dryers
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Dryers Logo
215 people viewed this question
Top Dryers Experts
