Question about GE 27GT616 27" TV
Television Fuse Pulled on the television cord and the television stopped working. Changed something in the set that looked like a fuse, but I got the fuse from a smaller television. I need to know if that part is called a fuse and where can I buy this part from.
  • 1 more comment
  • Bobby West Mar 29, 2007
    the fuse is glass with the two metal ends and on one end it reads...F5AL250V...I'm not sure what the other fuse reads because it is inside of the television(GE 27"), but the television just seems to run different, like the other fuse might be a lower voltage, which it probably is since it is from a smaller t.v.(Phillps 19")...
    Thanks in Advance,
    BStuart
  • richfill Jul 19, 2008
    I have a panasonic projection tv (crt type) and when I plug it in, the red power light blinks but the tv does not turn on...is this a fuse issue?
  • Rosalind Johnson May 13, 2013
    I have a panasonic viera in when the power goes of in the hose the tv don't come back on so I unplug it for two days then plug it back up then it work
  • 944 Answers
If it is a glass tube with a small bit of wire in the middle, maybe painted or with a label round the tube, two metal end caps, and a springy clip holder then yes, its a fuse. You should be able to get the same one at most hardware stores depending on the rating. usually the rating will be stamped in tiny letters on the side of one of the metal end caps, or on the tube if it is painted or labelled. It would say something like 6A or possibly 500mA or similar or maybe just the numbers with no A or mA. take the old one with you and you should be able to get a box of them cheap enough if you want. even if it has no numbers printed on it - look where the spring clips are and next to them or between them it will probably have printed "F1" or similar (meaning first fuse), and a rating like 10A etc. get one that is the same as the printed rating instead of the old one that came out if they are different. you might be lucky and find the one you got from the other tv is the correct one anyway, but you should check. Hope this helps - if not then please post again :)
Posted on Mar 29, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 29, 2007
    voltage is not directly an issue with a fuse. The Amp rating is the issue.
    a smaller Amp rating fuse will not make the tv work any different - it is just more likely to blow more often. sounds like there may possibly be another problem
    - just possible one of the connections from the power cord into the system has been pulled so it is not connecting properly - this could easily affect the voltage getting to the workings of the set. check along the cable as it enters the box to where it first joins something electrically - see if the connector or the soldered joints seem ok. also check the plug end - depending if you think that got pulled too - if so also try a different power socket in case something got bent inside the socket itself.
    the F5AL250V is a very standard "quick blow" 5 Amp fuse - the quick (or fast) blow bit means that it is slightly better quality, giving slightly better protection than what you might use in a less sensitive bit of equipment, so using any old 5 Amp fuse is not the best idea.
    You should be able to get the right ones though at most hardware stores - online prices are around $2 for 10 so shouldn't be too much.
    It does sound like it is the right fuse for the set.
    Please post again if you still have trouble
    Hope this helps :)
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
I have a philips 60pp9363 60in that worked beautiful for four years now it just wont power up period. No sound,no picture, no power light, no nothing. and it worked perfect yesterday.
The place to begin is with the fuse----with the set unplugged follow the power cord into the set---there is a fuse on the narrow right board--it can be checked--there are two on that board--one near the cord and another foward--you cannot just look at them--check them like any other fuse.
Sometimes a power surge or outage will take the AC fuse--it is the one right where the power cord comes in.
LET ME KNOW IF YOU NEED HELP OR HAVE ANY QUESTIONS.
sd tech
Oct 31, 2009 | Philips 60PP9363 60" Rear Projection...
Screen stopped working on 32 LCD
yes the fuse is called F-1.F-2 etc. labled on the circuit board usually near the power cord
Oct 03, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Power board fuse blowing
Remove the power board from the TV and look at the other side of the board. You should find the burn-out and then trace the printed board for a short.
Nov 28, 2017 | Olevia LT23HVX 23 in. LCD Television
Blown fuse
hi,you can locate the fuse near the power supply section,if there is power cord connection i think it is battery operated then check the battery.
hope it may help,
regards
Sep 08, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Fuse F3701 is blow-up after few munites turns on. If replace a fuse F3701 again, it work, but the set turns of any time, check the set: Fuse F3701 is blow again?
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Apr 16, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Hitachi 60ux58b projection tv
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Aug 18, 2007 | Hitachi 55FX48B 55" Rear Projection...
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
My TV doesnt turn on. where is ther fuse?
The fuse should be near where the line cord is attached to the power supply inside the TV. Be careful as there is a possibility of some DC voltage present from filter capacitors still holding a charge, long after the set is unplugged. If a fuse is blown and blackened, a new fuse will probably do the same when the set is plugged back in. Make sure you use the exact same rated fuse. IF the new fuse blows right away, do not repeat the process, it will only cause more damage. Good Luck.
Feb 11, 2007 | Samsung HCJ552W 55" Rear Projection...
Televison & Video Logo
4,205 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
