Question about Transcend T.sonic 610 MP3 Player
Not able to play all songs
When i connect this mp3 player to PC,then the removable drive shows 190 songs,but when I hear songs ,mp3 palyer shows a total of 150 songs only. The capacity is 1Gb,but then also mp3 player is not able to detect songs above 150.The screen shows message as 'song_number of 150',where song_number is the number of current track playing. pls help me out??
  • amit1987 Jan 08, 2008
    When i connect this mp3 player to PC,then the removable drive shows 212
    to detect songs above 150.The screen shows total no. as 150.
  • 8,596 Answers
Some songs may not be in correct format
also, could require a firmware upgrade:
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Posted on May 23, 2008
Thanks buddy problem solved after making 2 folder containing less then 150 songs
Posted on Oct 30, 2008
There is only one solution that make two or more than two folder in the root directory and put less than 150 songs in a folder then it will detect all the songs.
Posted on May 24, 2008
SOURCE:
How do i put music on my mp3 player from my pc
You connect the MP3 player to your PC using the U.S.B. port to your computer. It will show up on your pc as a new Drive like "E:" then you pick the songs you want from your PC and copy and paste them to the new MP3 player (the new detected drive). One suggestion don't cut and paste from your PC. Because you will be removing the song from your PC then and if you lose the MP3 player. ..bye bye to all your favourite songs.
Jan 04, 2015 | riptunes iptune 2GB P3 Player - Black
Driver for SanDisk Sanbsa m240 MP3 PALYER
FOLLOW THIS LINK YOU WILL GET THE DRIVERS.
http://www.sandisk.com/sandisk-support/driver-download-wizard
Oct 03, 2009 | SanDisk Sansa m240 MP3 Player
How to add songs to Philips SA2310 GoGear Mp3 Player 1GB MP3 Player from pc. does it needs any software??? where can i get that software?????
U DO NOT REQUIRE ANY SOFTWARE TO ADD SONGS TO UR PHILLIPS MP3 PLAYER. JUST USE UR USB CABLE TO CONNECT WITH THE PC. THEN U SEE ONE DRIVE NAMED REMOVABLE DRIVE COMES IN MY COMPUTER. JUST DOUBLE CLICK ON IT AND ADD MP3 SONGS AND THE SONGS ARE ADDED TO MP3 PLAYER. ENJOY THE SONGS IN PHILIPS MP3 PLAYER. GREAT SOUND.....
Sep 15, 2009 | Philips SA2310 GoGear Mp3 Player
How do you delete files from mr118?
you can delete files from within the mr118 but its a little tricky, the easiet way to do it is to plug your palyer into a pc using the usb cable
Then go to my computer, double click the player (it may show up as 'removable drive' ) if no songs appear they may be in the 'music' folder
once you have found the required song just right click it amd select delete. Btw I had a redmango 2gb player, bought it from argos, thought it was a bargin and it broke within a couple of months :(
Jul 21, 2009 | Audio Players & Recorders
I cant figure out how to take songs off my mp3 player
connect your usb cable to you computer. go to my computer and open the removable disk drive folder that shows the name of your device. Once you open the folder it will show you all the songs in your device. select the songs you want to delete and remove them by clicking the delete button on your keyboard.
rhea
Mar 16, 2009 | Sony NWZS616F Digital Media Player
Ilo mp3 player reads "*no files*"
my ilo mp3 palyers stores information which cannot be used because files are not present
Sep 14, 2008 | iLO (2 GB) MP3 Player
My problem is my mp3 player
Make sure the hold/lock switch is not engaged
Jun 24, 2008 | SanDisk Sansa m240 MP3 Player
Drives appear empty
ok all you have to do is this you need 2 reformat your mp3 and then it should be working fine
hope it helps
Jan 25, 2008 | SanDisk Sansa E280 MP3 Player
My mp3 player doesn't player
Use SonicStage to transfer music files. This can be downloaded fromthe internet.
Dec 05, 2007 | Sony NW-E002 MP3 Player
Remove songs that have been added to device
When your GPX MW3837 is plugged into your PC, it will show up as a drive [mine shows GPX(E:)] in Windows Explorer. Click on that drive and you will be able to delete anything from the MP3 player.
Nov 12, 2007 | GPX MW3837 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
160 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
k24674
Chris
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
