Question about Singer 7442 Mechanical Sewing Machine
Machine motor is getting stuck
My machine is less than 2 years old. It is having some major problem, one that I can't find any information about. While sewing all of a sudden my machine will "go NUTS," the motor goes into super fast speed (faster than the fastest it goes with the presser foot) and it doesn't stop, even if I take my foot off the presser foot. It does this even at the beginning of sewing at the initial time I put my foot on the presser foot, it also does it while backstitching. I have cleaned the machine like it says and oiled it, but it didn't do anything to change this problem. This problem is getting worse now, I don't think I can sew anymore with it. It was a gift, so I don't have a receipt. Any suggestions on how to fix it or what is the matter with it? Thanks,
    Genius:
  • 1,074 Answers
Check the foot peddal that it is not sticking if it is take it down and service it.if that does not work the motor needs to service also or replace.goodluck.
Posted on Mar 30, 2007
Husqvarna Huskylock 936. Handwheel won't turn, machine hasn't been used in a long while.
A thorough clean and oil would probably do wonders for the machine. These old mechanical machines are dependable but they do need some regular TLC because the old oil dries out and glues things together. I recommend not trying to run the machine until the problem gets addressed because it could damage the motor trying to run parts that are stuck together.
Below is what I've done for old sewing machines that have been neglected. Also, about once a year I perform a thorough clean/oil on my mechanical serger (as well as all my sewing machines). On my serger, I can remove the bottom (because that's how mine opens) and get to the moving joints inside.
Wheel on right side that controls the needle up and down is very tight...
Nov 15, 2017 | Husqvarna Sewing Machines
How do I remove the metal case of my sewing machine so I can replace a belt?
A: You asked, "How do I remove the metal case of my sewing machine so i can replace a belt?" Without the specific Make and Model number it is impossible to give a specific answer, so with such a general question you can only get a general answer regarding Metal-Case machines (since that is the only information you provided in your question).
Many Metal-Case sewing machines usually have either:
(A) External Motors and External Drive-Belts, changing the belt is easy and intuitive.
(B) Internal Motors that are Internal Direct-Drive and have no Drive-Belts to change or adjust.
(C) Internal Motors and Internal Belt-Driven Hand-Wheels, and this is what I assume you have. To change the belt:
(1) Unplug the machine.
(2) Remove the Top-Panel (usually 2 or 3 screws need removal). Some machines (very few) have a pry-off top that has no screws, just internal spring-clips that hold onto nubbins under the lid.
(3) Remove the Left Side-Panel that fits around and under the Hand-Wheel (if it has a side panel; and it may be plastic, there should be 1 or 2 slot-head screws holding it in place. If it just has 1 screw it is generally centrally located; if 2, one may be high and the other low. A few machines also have interlocking tabs that fit into the body, that must be un-puzzeled to remove.
(4) Loosen the motor Drive-Belt Pulley to remove the old belt (it is usually a slotted set-screw or a small Allen Wrench (Hex).
If there is a Part Number on the old belt, use, or measure the old belt and/or use the Part Number to help match it to a new belt. If you have a manual, it may show the Drive-Belt Part Number; there are also Parts Lists for many machines. Less expensive generic parts are often just as good, as long as they are of the correct size, configuration and installed properly. Avoid the rubber-band type giant O-Rings to Drive machines, Belts are better *.
(5) Replace the new Drive-Belt and Drive-Belt Pulley, adjusting the belt tension so the motor can reach full speed without laboring. "A Twee-Bit Too-Loose" is better than being "Too-Tight"., but best to be just right, that is to allow the belt to deflect a little if pressed in the middle, yet tight enough so there is no slippage. A lugged belt (often Orange color, but sometimes Black) makes it much easier, since there is no slippage due to the lugs, and it can allow the machine to turn easier (with less resistance than * tight O-ring Drive-Belts) to sew better with less motor- bushing wear). "Assembly" is the reverse of "Disassembly".
Sincerely,
-- Amender (2016 FEB 23)
Jan 30, 2016 | Sewing Machines
Wont start
the on/off switch could have gone out, make sure the wall outlet is working also, could be the power cord could be the problem, the machine needs to be serviced after sitting so long.
Dec 06, 2015 | Sewing Machines
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
Feeding foot does not work
Unfortunatly warranty doesnt apply to you. Warranty on these machine are 2 years for parts and labour. The motor's warranty is 3 years.
Jun 22, 2010 | Brother SE-270D Computerized Sewing...
I think I need a power board because my machine keeps stopping. Have to wait to start again. Also my light is broke. I have a 1171 and wondered if parts are still available for that machine. It was my moms...
Hi, ..go for the simple first. It could be motor brushes..the next time the machine stops try turning the handwheel and see if it starts to run again. If it does, the motor brushes are worn down. It would probably be less than a 100.00 to repair it.
Good Luck!
May 07, 2010 | PfaFF Tiptronic 2030
I have a Pfaff 1222E sewing machine which needs a new motor
Good for you, to repair a great machine instead of buying some more modern, disposable machine!
I found a generic motor that will fit your machine at http://www.pfaffmachines.co.uk/partsDB/index.php?function=detail&recordID=185. Free delivery within the UK, but that doesn't help much, does it? There's several places in the U.S., like http://www.a1sewingmachine.com/parts.html http://www.sew4less.com/QuickSearch.php http://sewingpartsonline.com/
You'll probably need to look for a generic motor for your Pfaff, but they should be out there.
I did check eBay; they do have generic sewing machine motors, but unless you're very experienced with eBay, I'd be very careful there.
Check with your local sewing machine dealer/repair place (even if they don't carry Pfaffs). Maybe they can help.
Good luck--I wish I could be more helpful, but let me know if anything I've sent helps, ok?
Robbie
Jan 31, 2010 | PfaFF Sewing Machines
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
Brother CS-6000i
I have the same problem but I believe the answer is to purchase a new shuttle which is the part the bobbin sits in and is most likely scratched or damaged. The quote I got was 40-50 dollars
Oct 27, 2007 | Brother SE-270D Computerized Sewing...
My machine locked up
check www.partstore.com they might be able to help you with manual.but you need to change the motor ot you machine and it will work.good luck
Apr 03, 2007 | Janome 2049LX Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
149 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
