Question about Candy FP855 Electric Single Oven
Cleaning above the grill element
Seems to be a fixed element but when using the cooker or the grill smoke is so bad it hurts your eyes.have cleaned the main oven but
cant seem to clean above the element easily any ideas.
  • Candy Master
  • 3,463 Answers
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Posted on Dec 18, 2008
Use a scraped, dont leave the grill on, i did the same and the grill set a light and the fat above it, i thought my house was going to burn down,, use oven pride and a small scraper
Posted on Feb 11, 2012
Smoking Oven when using grill
It appears that the smoke is excess fat / food splatters that have landed on the grill element. If you had a faulty element it would not work period Also check that any boil overs from pots above are not finding their way to the rear of the element.
Jun 10, 2013 | Ovens
Bought a house with Technica oven (5-6 yrs old), turned on grill and it smoked badly. All smoke going into room - should it be sucked up into oven vents ?(slots at top of inside oven when door open)....
The grill probably has some type of oil or cleaning agent spilled on to it. the only way i have done it is just burned it off. But I suppose you could pull the burners and wash with soap and warm water. It's much nicer to have a exhaust vent leading out through the range hood to the outside So if you have the time and money it's a relatively easy job to do. Good luck
May 16, 2011 | Ovens
Can i use one of those spray products to clean my oven , glass door and heating element. I have the problem of the oven smoking if i raise the temp over 220 to cook things such as pork.
If you're going to clean the element use just plain soap and water with a good rinse.. Anything you put on the burner that doesn't evaporate perfectly will smoke and may be bad for you when you open the door to see how things are going.
lp
Jan 11, 2011 | Ovens
Do I need to preheat the oven when cooking in the iven When using as a grill the grill smokes all the time
hi, what you need to do is turn the grill on and leave it on what is happening is all the steam and fat and grease form the cooking you have done in the oven has risen and stuck on the heating element the grill uses, so open your windows and turn the grill onto its highest setting and just leave it after a while the smoke will stop.
You need to do this so that any food you cook using the grill doesnt smell of the smoke thats burning on the grill element.
Dont worry you wont do any harm to it this is a very common problem with combo ovens and grills and the same goes for microwaves with the grill feature so dont worry to much its what happens over time if you dont use the grill much.
So just switch the grill on and leave it it can take upto 20 to 30min to stop smoking but after its burned off all the grease and fat etc it will stop smoking and stop smelling so dont worry everybody who has one goes through this same problem.
let me know how you get on or if you need further assistance ok.
Its best you do this once a week or so to ensure that it dont build up to much as it can really stink the whole place out and if you cook food without burning it all off your food will taste like the smell witch believe me isnt nice, so just leave it all to burn off leave your windows and doors open and after about 20 min you should find the smoke will stop and the smell will go away.
You may find it only takes 5 to 10 min but dont worry no matter how long it takes your not doing any harm your just cleaning the element.
Dont try cleaning it with cleaning products as this can cause harm to the element and could taint any food with the cleaning product you use.
The only real help you can give is that before you turn it on to burn off the grease use a stiff hand brush and brush the element to remove all the dried on loose bits this will then make it quicker to stop smoking.
But other than that just leave it and it will sort itself out.
Jan 13, 2010 | Creda Europa E010E Electric Single Oven
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
Jan 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven smokes
If it smoke smells of burnt food or grease you have something on the surface of the element which is burning off.
If it is an acrid smoke it could be the element itself is on the way out or the fan (if it is a fan oven).
You need to make a visual check of the element/fan to ascertain their condition and clean or replace as necessary.
Nov 30, 2008 | Ovens
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
Too much smoke in the oven
really the only reason for smoke is fat on the elements especially the grill element. suspect problem may be due to what you are cooking
Jun 18, 2007 | Electrolux EOB6636X Ultrafan Electric...
Candy FP855 Electric Single Oven Logo
843 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
