Question about Dell Dimension 1100 PC Desktop
Dell motherboard 0WF887 keep getting graphic failure on lights
Dell dimensions 1100 received lightning damage from phone line. I have replaced everything in this PC. I have replaced the motherboard three times with used motherboards that have been tested and checked OK. The diagnostic lights on all three indicate graphic failure which is part of the motherboard. I have used the same processor on all three. The monitor has no video because of the graphic failure. What am I overlooking here? Richard
  • 9 more comments
  • mobufalow Dec 19, 2008
    Yes, I replaced the graphic card three times, as I reported it is part of the motherboard.
    My first report I stated I replaced everything.power supply,memory board,processor,cables,harddrive,modem,motherboard three times because the ABCD lights tell me the graphic board is bad and it's part of the motherboard.
    The video card is part of the motherboard.I have used the original processor and a replacement processor. I get the same results.
    I replaced the power supply with a new one and used the original. Same results.
    I replaced memory and power supply.
    I added a PCI graphic card from Best buy. It did not work.
    This dell motherboard limited to the kind of graphic board you can use. The one I used from Bestbuy was it.
    ABCD lights are on the motherboards. The monitor I used on it is the one I'm useing now.
  • mobufalow Dec 20, 2008
    I did replace the hard drive.I have stated this twice before.
    There is no beep on start up and Ican't tell on video, because thats my problem. The monitor is working because it works on another PC.
    The graphic card is part of the motherboard which I have replaced three times. I also added a new PCI graphic card and that didn't work. The processor has also been changed.
    Scholar:
  • 145 Answers
Hi Richard, You are overlooking The monitor, the processor and SMPS. Please understand the computer circuitry is uses very low voltages and everything which was connected to at the time of lightning has high possibility of being damaged, even the cables which connect different components(internal and external).
My recommendation is you better go for a new shopping for altogether a whole PC and scrap the old one. One more thing, just check your household insurance, it may have a relevant clause ,which may help you to get a reimbursement. Good Luck.
Please rate me if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 20, 2008
  • Dell Master
  • 19,396 Answers
Check that all the screws on the motherboard are well in place, they ground the board. Look for any possible short to the chassis. Unplug all chassis connectors to motehrboard and test a different switch.
(a tech can use a screwdriver to to jump the contacts and start a MB, but there is risk to damage your MB if you do it wrong).
If you have not replaced or tested different RAM yet, remember that many onboard graphic chipset use shared RAM .
    President:
  • 2,110 Answers
Is there any error message or Beep on booting pls tell me..
Posted on Dec 19, 2008
  • 275 Answers
Sounds like you created a whole new computer after replacing all those parts. Maybe hard drive is damaged as well that's why you don't get anything in the screen
  • 1,879 Answers
Almost everything has been replaced except for the tower case, is that where you see the ABCD lights ?
monitor still ok if connected to another source/computer ?
  • monk3ybidzness
    monk3ybidzness Dec 19, 2008
    try powering the board outside the case (just hook up the power supply, switch and monitor)
  • monk3ybidzness
    monk3ybidzness Dec 20, 2008
    we need to eliminate the case/tower.
    board + power supply + monitor + quick short the pin for power switch
  • Dell Master
  • 1,800 Answers
In this case try to use a seperate graphic card with EXpress/AGP/PCI Video Graphics til u get a result also check the ram modules thats might be a problem with the RAM Frequency with Mother Board
  • Jalal Sordo
    Jalal Sordo Dec 19, 2008
    this is a hyper strange problem how come u r replacing the motherboard three times with no result???
    also check all the hardware that u r putting in the board before plugging it tell me what is the hardware is connected to the motherboard now??
  • Jalal Sordo
    still one thing to change the Processor. try to get same refrence of processor that compatible with the motherboards i mean the same one and restore all ur old compenents also ur first motherboard.
    cuz the processor have taken a high voltage shock.
    Genius:
  • 1,199 Answers
Your going to have to replace memory and power supply too!
    Sergeant:
  • 233 Answers
Are you SURE the power supply is good? I have seen power supplies that will power the motherboard enough to light the LED's and turn on fans, but not actually POWER the board... try substituting the power supply if you havent already.
  • 136 Answers
Since the same processor is used for all and all have the same problem, I would say that you should try another processor. You should also check using different video cards.
Posted on Dec 18, 2008
  • 2,336 Answers
Have you replaced the power supply?
How about the memory?
    Sergeant:
    Champion:
  • 247 Answers
Have you changed the graphic card?
  • 1 more comment
  • Thomas Dec 19, 2008
    i would try installing a seperate graphic card and see if that works.
    welcome-
    i next thing tath i could sugest is using a different processinf chip. with the computer being hit by lighting it might have done some damage to the processing chip.
    thanks
    Tom
  • Thomas Dec 20, 2008
    i think that your motherboard is shot. sorr for the bad news.
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
Dell dimension 1100 b110 drives audio e rede
Hello download the driver here at dell:
http://www.dell.com/support/troubleshooting/us/en/19/Product/dimension-1100
Open the audio folder, and download the driver.
Run the exe program, and reboot after the install is done.
Good luck
Mar 04, 2013 | Dell WF887 - Dell Dimension 1100, B110...
I have Dell Computer Corp. 0WF887 Motherboard and i'm thinking about upgrading my ram. What ram would be compatible with my pc. DDR?
List the computer and I can tell you. Or Typically you can pull out a stick of RAM in the computer and it will list either the type example (DD3 PC 1066)
A good resource for finding the current ram, how much your computer can hold and even buying it is here. http://crucial.com/
Just select your make and model
Comment if you need anything else.
Thanks!
Sep 08, 2011 | Dell (0141E) Motherboard
Blank screen
I have gone rounds with these dam dells and still have one sitting here that I have not fixed and i can tell you get a new box totally and put your hard drive in another one
Sep 24, 2009 | Dell Dimension 4600 PC Desktop
Fix graphics card on Dell Dimension E510
something on the motherboard may be damaged, if you replaced a power supply the motherboard really needs to be checked to see if there is any damaged components on it. my best guess is there are damaged components on it and you may need a new motherboard as well
May 09, 2008 | Dell Dimension E510 PC Desktop
Ethernet driver(s) for dell motherboard (0WF887)
Yes you can get your drivers at www.dellsupport.com and put your express service code into the space provided,
Your service tag should be located on top the case, Or on the back should be by the COA and then it will take you to the spot you can find your Broadcom internet and wireless drivers there.
Hope that gets you going If not just write back here and I will get them for you.
Jan 17, 2008 | Dell Dimension 1100 PC Desktop
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 1100 PC Desktop Logo
37 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
