Question about Intel Motherboard
Computer comes out if standby!
Computer comes out if standby by itself after 3 minutes. I checked the BIOS there's no Wake up by LAN setting. I'm using windows XP & Intel motherboard. how can i fix this?
  • 24 Answers
Ok right click your desktop/ click properties/then click screen saver/then click power under monitor Power and you can chance the amount of time for standyby and all of that and it should be good
Posted on Dec 18, 2008
My HP Media Centre Model M7460 wakes itself up overnight when left in Standby Mode. I have disabled everything that I can think would be waking it up - but the probelm persists During the daytime - in...
It is possible that you have a CA Voltage problem... so, do you have overvoltage protection at power supply?. though you should remove jumper from "boot block" pins (or similar) in the Motherboard (HP computers usually have it). This surely willl help you.
Greetings!
Apr 19, 2010 | HP Computers & Internet
How to enable GA-EP43-UD3L motherboard wake on lan?
Most modern ATX motherboards should have a 3-pin Wake-on-LAN connector near the PCI slots and should included BIOS support for Wake-on-LAN power up,check the Power Management Setup for this option.
As i check in your motherboard manual there is not pin but it supports wake on lan so go to bios and enable power on ring in power managment,it should be enable by default.Next right click on your computer,then properties,then device manager(OR YOU CAN SIMPLY GO TO START->RUN AND TYPE devmgmt.msc and hit enter).Then find the network adapters,click on it,and click on your ethernet controller(it should be realtek,gigabyte something like that) and the go to advance and scroll(search) for "wake up on lan" "wake up capabilities" and make sure that is on or enabled AND YOUR DONE:)
Jan 11, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Hi I have an MSI 865GM2 Motherboard and Logitech wireless mouse and keyboard. I want them to be able to wake the computer from Standby or hibernate, but cant get it to work. There is no power management...
Yes, you need to go into the BIOS at boot time. Look for a set of "Wake on" settings (LAN,Modem, Keyboard etc). Probably under either Chipset or Integrated peripherals.
Nov 30, 2009 | MSI 865GM2-LS Motherboard
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
XP Computer Standby Feature Question
Have you disabled "Wake on LAN" in the power settings? There are also other settings in Power management that could affect this.
There should also be general settings for power savings such as "none" "medium" and "maximum power savings" With a little explanation of each.
Jan 27, 2009 | Computers & Internet
My computer comes out of standby mode after 3 minutes. i checked the BIOS and there's no Wake up on LAN option!
It is probably a setting in windows that is your problem.
Try This, Right click your screen and select properties,select the screen saver tab, then select the power button. If you don't want power saving highlight never for the monitor and hard disk. Then go to the hibernation tab and disable hibernation.click ok to all screens to back out. Hope this helps.
Dec 18, 2008 | Computers & Internet
D945GTP comes out of standby automatically
Check out all of your power options. Also make sure that none of your keys on your keyboard are stuck or mouse buttons. If anything touches yoru keyboard or mouse, it will come out of stand by.
Nov 30, 2008 | Intel D945GTP Motherboard
Stand by mode
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Nov 28, 2008 | Computers & Internet
When I put the computer to "sleep" it decides to come back on by itself. This happens frequently, but not all the time. What could be causing it to do this? Also, if I shut the computer down,...
Sleep on Vista is a combination of Standby and Hibernate. First it will go into Standby and then later if a laptop it will go into Hibernate. Any movement of mouse or keyboard may cause it to wake up.
Some computers will wake on Lan. If you have ethernet connected this may be the cause. You can turn this off by using Device Manager - Hardware - Select ethernet adapter - driver - Advanced - look for Wake on Lan and Pattern Matching and disable this.
ALso check your BIOS settings and disable all Wake on XXX settings.
Nov 15, 2008 | HP Computers & Internet
Dell Inspiron 1525 with Vista
I'm out for the evening, but I'll be back tomorrow morning. Leave the info and I'll get you a solution.
Jun 20, 2008 | Computers & Internet
Intel Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
