Question about Canopus ADVC100 A/D Converter (CANOPUSADVC100)
All indicators on
The box shows all the indicators on when switched on
0 characters
1 Points
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
Mar 12, 2015 | RCA (DTA800B1) Video Converter
How do i connect many devices (sky box X 2, bt box, etc) to 4 tvs in public house
You will only be allowed to watch 1 channel at a time if you have one box and use coax cable. If you have WI-FI using a sling box and roku (apple TV) adapters you can change the channel at each location but you still will only be able to watch one channel but you could watch the channels available on Roku. Best solution,and also the most expensive , is to have a cable box at each loaction.
Oct 17, 2014 | TV Accessories
Yes hello, i'm trying to hook up my Coby 12'1 digital tv to a converter box is that possible or do i need a cable box for it to connect?
You should be able to connect the tv to a converter box. This is good for OTA signals to a TV with an NTSC tuner (coax) or composite video input. has the manual for the DTV102. Put the antenna coax cable to the converter box ANT In and then either the antenna out to the TV or the A/V (composite) out to the TV's composite in. If you use the RF connection, you will need to set the TV to channel 3 or 4 and set the switch on the converter box appropriately. For a composite video connection, you will need to change the input to AV1 (if there are several inputs). Depending on the TV, there may be a source or input button on the TV. For other models this is only on the remote. If you have the original remote, no problem. If you have a universal remote, make sure that you have a key that corresponds to the feature and that you found the code that lets the key work for your TV. (Not all universal remotes have the feature.)
However, you should get the best antenna that you can and have it pointed correctly to receive the stations. Digital signal doesn't have borderline reception. Try or to check the stations and directions in your area. Antennaweb assumes an outdoor antenna but is very conservative in the channel list that it will indicate you can receive. Tvfool lists the channel reception depending on the antenna type. Tall trees and buildings can block the signal.
I hope this helps.
(please note that surges from the antenna can damage converter boxes and kill the tuner.)
I cannot save video to my pc. Is the preview sceen supose to go blank when recording?
The small screen should play what is being recorded. Make sure you push 'play' on the VCR2PC before you click the 'record' button.
Feb 20, 2010 | ION Audio VCR 2 PC USB VHS Video to...
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Channels are not available on phillips tv
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
install the drivers again, drivers are not installed properly, try to switch slot, if it still gives you this error.
Feb 17, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
VGA 1 Detecting prob
Hi, it sounds like your driver file is missing or corrupt. If you have the orriginal driver disk Delte the driver and re-install it. If you don't have the disk, go to the manufacturers web site and download it. Regards mistyman
Sep 29, 2007 | Philips E-box FTR9964 Video Capture
Canopus ADVC100 A/D Converter (CANOPUSADVC100) Logo
13 people viewed this question
Top Canopus TV Accessories Experts
Brian Sullivan
Brian Sullivan
Yoav Shilon
Yoav Shilon
isaac johny
isaac johny
Are you a Canopus TV Accessory Expert? Answer questions, earn points and help others
