Question about Sharp Notevision PG-B10S Multimedia Projector
Projector not turning on after repalcing lamp
I was reading your solutions i tried the holding the menu and power buttons down and is still nothing
If power indicator is flashing, check that the innerswitch by the lamp cover is closed.
Posted on Dec 25, 2008
The machine starts, eventhe vent, but no image appears. All the lights, except the POWER SAVING one remain lights on.
  • Plug the projector into the wall and put it into standby mode. You should have already replaced the projector's lamp with a new LMP-P200.
  • Press the "Reset," left arrow, right arrow and "Enter" keys on the projector's control panel. Press them in the exact order listed here, one after another, and press each key for less than five seconds.
  • Turn the projector on with the "Power" button. Press the "Menu" key to enter the projector's menu settings.
  • Press the down arrow to navigate to the "Install Setting" menu and press the right arrow to select it. You should see the lamp timer at the bottom of the screen. If you have correctly reset the lamp timer, it will indicate 0 or 1 hours.
  • Press the "Menu" key to exit the menu system.
  • Read more : http://www.ehow.com/how_6900249_reset-lamp-timer-sony-vpl_px20.html
    How to Reset Sony Projector eHow
  • Turn on your Sony projector after replacing the lamp.
  • Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
  • Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
  • Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
    Jul 02, 2015 | Sony VPL CS4 Multimedia Projector
    How to reset lamp hour of panasonic pt lam1 lamp
    hi,
    Do the following for reset the lamp hour timer of Panasonic PT-LM1U
    1. Power ON the projector. (wait for the display)
    2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
    3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
    4. Press and hold Enter button for approximately 3 minutes.
    5. The LAMP RUNTIME will change to TIME RESET. (power off).
    6. Turn off the power.
    OK
    Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
    I have replace the lamp but any how i am not getting any response from projector. As after replacing the lamp projector was ok. It shows all the thing but second time. No response. pl suggest
    hi,
    you didn't mentioned any thing about the indications. is there is any indication on the projector. if projector have some problem it will show the indication for the same using its self diagnosing system.
    just do one thing check the power cable and the power at the socket to which you have connected the projector. if these are ok and the projector have no indications on its panel, then the smps power supply in side the projector have some problem. if so it is difficult repair the smps by the user. need good knowledge of electronics servicing, because there is harmful high voltage points.
    Is there is any indication on its panel, then if you discribe the same will provide you the exact solution .
    Also try to check the inserted new lamp , lamp cover is it properly closed etc.
    if the projector starts try to reset the lamp hour
    1. Go to its menu select option2
    2. From the option 2 menu select lamp runtime
    3. Press and hold the enter button for approximately 3 seconds
    4. After resting just power off your projector and turn it on again.
    Also check one more thing
    The "CONTROL KEY" may be set to "OFF". In order to set the "CONTROL KEY" to "ON"
    without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
    ok
    Apr 04, 2011 | Panasonic Videoprojector PT-LM1E...
    Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
    press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
    The "LAMP RUNTIME" screen will be displayed.
    (NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
    Press the POWER button to turn off the power.
    The POWER button on the projector illuminates red.
    This will reset the cumulative usage time for the lamp unit to "0"
    Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
    What will I do to reset lamp timer for my Panasonic PT-AX200 model
    Read very carefully this is the only solution to reset lamp timer
    1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
    3. Press the MENU button to display the menu.
    4. Select the OPTION menu and press the ENTER button.
    5. Select LAMP RUNTIME.
    6. Press and hold the ENTER button for approximately 3 seconds.
    7. The confirmation screen will be displayed and select OK.
    8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
    9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
    Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
    How do i reset lamp hours for a toshiba TLP-T721
    I have not actually tried this but on a different post, here's the wild solution:
    Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
    1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
    2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
    3. The lamp operation counter will automatically turn to zero
    4. Check if the lettering "0H" appears on the lamp operation counter in the status display
    5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
    Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
    I cant get the message lamp life is ending off
    Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
    May 30, 2010 | Toshiba TDP-S8 Multimedia Projector
    LP 530 Lamp does not power on
    Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
    To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
    If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
    hope this helps... Regards Vortash
    Feb 27, 2008 | InFocus LP 530 Multimedia Projector
    Reset Lamp Hours Timer
    This works on a couple different Toshiba models -- might work on yours...
    Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
    Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
    Sharp Notevision PG-B10S Multimedia Projector Logo
    104 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
